Re: p.p o`connors.heavy haulage
they went on Monday mornings, ferry nearly always empty that time of the week going too Ireland.
Was a problem at Blackwall Tunnel ( education enough at over 60ft ) so I was going to use Dartford ( £42 + escort even empty ). Took him a while to convince me I could get on the Woolich Ferry :eek: Like most things, once you've done it, no drama but that first time I was like a young teenager going round to meet girlfriends dad for first time :D |
What do they do to solve that problem?
Sheet of teflon and a run up? :) I can't see them getting the ferry to ballast down, and the link span only moves at one end. |
Use to get weight off back axles to realign them / charge suspension by raising neck then blocking under rear edge of bed, then lower neck, bed hinges on the blocks and raises the rear end. ;) |
Blimey, there was me thinking they were just standard air bag systems!
What is the suspension - I've seen the fluid type with accumulators on a hyd neck wedge trailer. I'd love to go out on a days work as drivers mate just to see loading and shifting something huge! |
I found out, pulling a Megabite crusher (around 40t ) out of Sandwich just after I went on it. Well loaded at about 60t gross I was pulling up out of Dover heading for M20 ( was too heavy for A2 ) when I spotted smoke / steam ? something ? from back end. Turned out tyres on one side were rubbing on the arches. Phone call to office and I was talked through the proccedure of how to get the weight off (blocks under rear of bed) then recharge system with oil using an adapted grease gun stowed in box on neck :cool: |
Good stuff. Grease guns will generate a serious pressure.
Sounds like hydro-elastic suspension, like citreons, mgf's, metro's etc. On a bigger scale! |
