  #1   IP: 109.156.50.130
Old 08-08-2018, 08:35 PM
kryder's Avatar
kryder kryder is offline
Default JCB 3CII backhoe help
Hi all,
Newbie question..............
I've got a burst hose on the backhoe but can't get at one end of it to replace. How do you get the backhoe to move away from the chassis? Is it via the circled lever in the attached picture? If so, it's seized up Any tips on how to free it - bearing in mind that I've got a burst hose!
  #2   IP: 31.50.134.18
Old 08-08-2018, 08:51 PM
Default Re: JCB 3CII backhoe help
Which end of the hoscan you get at? If it's the end nearest the supply you could uncouple it and fit a blank then you can operate the machine without loosing more oil.
At the end of the day it's going to get very dark!
  #3   IP: 109.156.50.130
Old 08-08-2018, 08:54 PM
kryder's Avatar
'fraid not - it's the end nearest the supply that I can't get to........
  #4   IP: 90.252.12.42
Old 09-08-2018, 05:49 PM
The clamps should loosen up if the machine isn't used for a couple of days. you might be able to winch or push it over with another machine if you have one available? Depends what position the arm is in as to how easy that will be to achieve.
  #5   IP: 109.147.188.81
Old 09-11-2018, 07:12 PM
LONGREACH1976 LONGREACH1976 is offline
Hi dont know if you got your bach hoe repaired you could cut the hose fit a reusable fitting make pipe to fit then machine will work
