  #1   IP: 31.48.204.32
Old 19-05-2014, 08:40 PM
steveaki steveaki is offline
Default Cat D8L
Hey Up
Were in the process of buying back our D 8L in the next few weeks but need to fit a ripper.
I think I have sourced a 4 piston m/s ripper of a 9H will it fit? I was told they do.
Does any one know where to get a ripper valve and all associated gubbins and any decent hands to fit it for me .
Any help much appreciated.
  #2   IP: 188.29.74.17
Old 19-05-2014, 09:44 PM
lynchy's Avatar
lynchy lynchy is offline
Default Re: Cat D8L
Steve Holiday,used to be on with Stevens,had garage up on kingmoor good bloke with plant or andy atkinson at AA Engineering in Lancaster,probs be able to sort 'gubbins' and fit it,or of course Tony Coates,tc tractors,the 'dozer man' extrordinaire!
  #3   IP: 92.3.172.222
Old 19-05-2014, 10:01 PM
Mark10's Avatar
Mark10 Mark10 is offline
Default Re: Cat D8L
Don't see many d8's about now think I have only seen one in my lifetime an old d8n.
  #4   IP: 92.12.154.69
Old 20-05-2014, 05:31 AM
Default Re: Cat D8L
There!s a few about Mark. Blackwells have several N's, Barton plant in Northants have an N or two. Searles have an L and H's and there is another L in Sussex in a chalk pit. A fair few H and K series all over. Roly has seven.
Steve, I think messia corp in Essex has a ripper on an old 8K. they advertise in the Resale.
  #5   IP: 85.255.234.137
Old 20-05-2014, 08:32 AM
Default Re: Cat D8L
Lynchey il try those boys there both fairly local to me.
I heard that Steve Holiday is good on Volvo dump trucks.
Trax I have found a ripper off a D9H I'm led to believe they fit D8Ls as there realy a D9.
Is messiah breaking the 8k as it's the ripper valve and spools I'm after.
  #6   IP: 85.255.234.137
Old 20-05-2014, 08:34 AM
Default Re: Cat D8L
I'm also looking for a hydraulic 463 box if any one knows of one.
Got a big top soil strip starting in a months time and the 8&box wld be ideal for the short haul stuff.
  #7   IP: 95.148.204.173
Old 20-05-2014, 09:04 AM
Default Re: Cat D8L
cable 435? but cheap and two of them
http://www.ebay.co.uk/itm/CATERPILLA...item27e4319802
  #8   IP: 188.30.21.113
Old 20-05-2014, 09:18 AM
Default Re: Cat D8L
Cheap if it's 3300 for the two. I have a real corker bought for half that amount. It is said that D8's pulling 435's pack the muck in too tight and there are problems ejecting. If converted to hydraulic this should not be an issue.
  #9   IP: 85.255.234.137
Old 20-05-2014, 09:59 AM
Default Re: Cat D8L
GB
Thanks for that I called the guy and he has a 463 for sale going to look on Friday.
  #10   IP: 85.255.234.137
Old 20-05-2014, 10:24 AM
Default Re: Cat D8L
Trax
What is the heaped m3 of the 435 is it a box more suited to a d7 size tractor.
