  #1   IP: 31.52.247.96
Old 28-06-2018, 09:18 PM
PB1507 PB1507 is offline
Default Wanted International BTD20 service/parts book
Hi All, I have recently bought a 1968 International BTD20, It needs some work and a service/parts manuals would be very useful. Also on the look out for various parts .
Regards Philip
  #2   IP: 78.145.243.112
Old 28-06-2018, 09:37 PM
Default Re: Wanted International BTD20 service/parts book
Sorry I can't help with this
Have you got much info on it's history?
  #3   IP: 31.52.247.96
Old 01-07-2018, 12:19 PM
I bought the BTD20 in January from a farm near Southend, It had been stood outside for 10+ years but its general condition was good. It has a Turner 3 point linkage and blade. After a good wash, I removed the injectors and inspected the bores for water damage. It was good news no sign of water and the bores held diesel so very little wear, the engine was then turned over by hand then cranked over on the starter motor. Valve clearances set, recon injectors fitted, diesel system cleaned, new oil and filters and she started on the button
After a trial run across the yard, it was back in the shed and rectify the following.
1. exhaust manifold leaking, found to be paper thin and in need of replacement.
2. only steers one way, rh brake not working so removed the brake inspection plate.!! out came 5 gallons of oil and water So needs a seal or two plus recon brake bands.
3. Top rollers shot.
4. Track tensioners seized and no doubt need new seals.
5. 3 point linkage needs freeing off and some replacement fittings.
I have a feeling this list may keep growing.
Philip
  #4   IP: 86.130.166.14
Old 01-07-2018, 01:50 PM
Philip
Diggerhayne has one that he has just restored
  #5   IP: 1.121.127.215
Old 01-07-2018, 02:50 PM
ianoz. ianoz. is offline
Says it is a copy so not sure of the Quality
https://www.agrimanuals.com/internat...al-14667-p.asp
  #6   IP: 78.145.243.112
Old 01-07-2018, 08:07 PM
Philip
Beauty. I spent some time on one previously owned by English Heritage. But no 3 point linkage on that one.
  #7   IP: 94.2.173.62
Old 01-07-2018, 08:23 PM
romneyman romneyman is offline
To replace the seal that has allowed oil into the clutch/brake housing is quite a big job, you will need to remove the steering clutch to do it. Peter
  #8   IP: 31.52.247.96
Old 01-07-2018, 08:29 PM
Thumbs up Re: Wanted International BTD20 service/parts book
Thanks for the link.
  #9   IP: 31.52.247.96
Old 01-07-2018, 08:37 PM
Thanks for the help, I am new to crawlers so learning all the time, but not a novice in the workshop.
I will try to add another picture
  #10   IP: 31.52.247.96
Old 01-07-2018, 08:41 PM
And I have another, er , project.
