  #1   IP: 89.105.115.242
Old 27-10-2014, 09:15 AM
Craig99 Craig99 is offline
Default Yale forklift
Hi all,
I'm thinking about getting a Yale forklift and want to know if they're high quality machines before buying anything. If you've used a Yale machine before, would you recommend them or not? Please let me know, with an explanation of why. I prefer hearing from actual customers rather than relying completely on websites.
Cheers,
Craig
  #2   IP: 81.153.76.181
Old 27-10-2014, 09:59 AM
Default Re: Yale forklift
Originally Posted by Craig99 View Post
Hi all,
Cheers,
Craig
Hyster - had several for 30 years, 2 to 7 tons - bullet/bomb proof. Built to last - forever!! Quality product and good back up/spares availability!
  #3   IP: 90.217.1.140
Old 27-10-2014, 10:46 AM
DPC1973 DPC1973 is offline
Go for an EP truck. Most forklift trucks are now built in China. EP for example build Nissan, Hyster, Utilev (Hyster budget brand) and Manitou all in the same plant as their own trucks! You wouldn't believe it. Most components are the same too under the paint.
  #4   IP: 81.153.76.181
Old 27-10-2014, 10:58 AM
" Learn something new every day "
As far as the older Hysters go - they'd always be my choice - built like tanks!!
Have used many others and had a few Toyotas too, which aren't bad tools, but my first choice would always be as above
  #5   IP: 31.124.150.47
Old 27-10-2014, 01:58 PM
I don't think you can obtain specific spares for Yale trucks.
Check out spares and service back up first.
I would go for a common make like Cat, Nissan, Toyota, Komatsu. Etc etc
  #6   IP: 81.142.140.50
Old 27-10-2014, 03:12 PM
steviemax steviemax is offline
Hyster and Yale Forktrucks are exactly the same truck! They are built in the same factory, some of the range right here in Northern Ireland. The only differences are cosmetic.
  #7   IP: 92.12.155.250
Old 27-10-2014, 05:39 PM
I see, so are Yale still sold new ?
  #8   IP: 89.105.115.242
Old 04-11-2014, 11:30 AM
Hyster seems to be winning the general vote here, cheers all for your input! Interesting that so many "different" forklifts are actually the same.
  #9   IP: 176.253.206.241
Old 04-11-2014, 05:18 PM
imhad an old hyster, it was the mutts nuts, never went wrong, always did what i needed of it. but couldnt comment on newer gear, this one had side shift on it which was pretty special in its day, thats how old it was
  #10   IP: 86.191.190.201
Old 04-11-2014, 05:26 PM
bri963 bri963 is offline
I'll vote for Hyster. First industrial truck I ever operated back in the '70's. They had a rocker pedal for forward/reverse, and were one of the fastest small trucks, even by today's standards. Yale were good, built like tanks and about as manoeuvrable.
forklift trucks, yale
