  #1   IP: 185.16.224.33
Old 10-02-2018, 03:55 PM
scoffcruddle scoffcruddle is offline
Default Radiator recore,plastic top?
Can plastic top and bottom radiators be recored?
Loadall rad has started leaking at bottom,it's mostly eaten away no damage,£430 for a new one is best price I can find.
  #2   IP: 2.24.98.123
Old 10-02-2018, 04:21 PM
Cartman Cartman is offline
Default Re: Radiator recore,plastic top?
I fitted a new one for a chap last year, same dilemma. As it was a machine he needed every day to feed his cows he bit the bullet and went for new. In theory a new core could be bonded to the tanks again (in theory you can also plant a feather and grow your own hen) but there's very little left when you remove the core and the plastic will inevitably get stressed a bit during dismantling plus it's going to be aged and brittle going forward. My advice is unless you are a dealer moving the machine on go new, the day in the future you're sitting with a seized engine that radiator will have looked good value for money. We asked a local radiator repair service about it and he didn't want to recore it for the reasons outlined above despite having made us numerous radiators from scratch in the past so his advice was good enough for us. Ironically the plastic tanks are a performance downgrade as they don't radiate additional the heat the way metal ones would but they cost the bean counters a fraction of the cost of a metal tank so you got plastic then. New design is always primarily aimed at increasing margin not product performance. I suspect a complete radiator costs JCB in around the £100 mark.
  #3   IP: 86.174.112.10
Old 10-02-2018, 06:30 PM
Yes had a 3cx one leak , put a can of K seal in it and it never leaked again , local rad place were lined up to do it
  #4   IP: 209.93.206.133
Old 10-02-2018, 10:05 PM
Worth trying K seal, it is really good stuff. Used it a lot on Landroverís and it always sorted out the leaks.
  #5   IP: 81.151.174.184
Old 11-02-2018, 12:35 AM
and if it worked on a Land Rover rad ........ it'll work on anything
  #6   IP: 185.16.224.33
Old 11-02-2018, 10:51 AM
Usual thing with age the ally has gone powdered,I'd prefer a new rad with ally top and bottom,not keen on plastic had one split on a tractor last week.
  #7   IP: 185.16.224.33
Old 14-02-2018, 04:28 PM
Took radiator in today and chap said it was going to cost the same to repair as new,he did find me a better price on a new one though.
£395 compared to £430,only downside is I need to collect it.
You see, in this world there's two kinds of people, my friend: Those with loaded guns and those who dig. You dig.
  #8   IP: 81.151.174.184
Old 14-02-2018, 08:58 PM
can you not get it collected by a carrier or parcel collection service Boyo
this lot collected my fuel transfer pump for me most recently and have used 'em quite a bit in the past.
https://www.myparceldelivery.com/?ut...m_medium=email
Circa a tenner, for up to 30kgs, IIRC
  #9   IP: 185.16.224.33
Old 15-02-2018, 03:00 PM
It was only 10mile away,sent our peg and the cherubs.
  #10   IP: 81.151.174.184
Old 15-02-2018, 08:00 PM
ah right ..... not such a flog as 100 miles away then
