  #11   IP: 86.137.173.141
Old 25-04-2011, 01:50 AM
redjag redjag is offline
Default Re: Grease Nipple Sizes
Hi
I think you might be right - I had not thought about the nipple being damaged before you mentioned it.
There are two like this.
Peter
  #12   IP: 121.222.132.78
Old 25-04-2011, 01:53 AM
ianoz. ianoz. is offline
Yes , I am with wazza on this . Defineatly just a damaged nipple . Replace it .
  #13   IP: 123.2.47.139
Old 25-04-2011, 01:55 AM
wazza of oz's Avatar
wazza of oz wazza of oz is offline
That's a relief ,I was sure I was going to get egg on my face .
  #14   IP: 86.137.173.141
Old 25-04-2011, 02:00 AM
Smile Re: Grease Nipple Sizes
Thanks Guys
I will replace the broken ones with standard nipples.
Thanks again for your help
Peter
  #15   IP: 121.222.132.78
Old 25-04-2011, 02:40 AM
Isn't it amazing how a photo clears up any confusion , Once forum members are able to see exactly what some one is talking about .
I do hope some others on here take note
  #16   IP: 90.196.146.217
Old 25-04-2011, 07:45 AM
Have to agree 100%, its damaged. I'll have a dig in my box and see if I can get a picture of how it should be.
It is probably angled for easy access but doesnt mean you have to replace it with the same if you dont have one. Swap one from somewhere else so you can get some grease in it until you can get a new one.
  #17   IP: 90.196.146.217
Old 25-04-2011, 09:17 AM
Hope this helps. The broken off part appears removable on these.
  #18   IP: 95.144.191.52
Old 25-04-2011, 09:31 AM
Damn early birds
If I where you red, Buy a Big box of grease nipples (you probably already have them) And just carry it round. When I first started driving the JCB 531 I replaced all the Awquard greasenipples with ones that where angled/easier to get at and harder to damage/not going to be damaged.
  #19   IP: 88.108.162.3
Old 25-04-2011, 12:17 PM
modelman093's Avatar
Damn early birds
Worth remembering that an awful lot of older kit uses BSP threaded nipples rather than metric.
  #20   IP: 121.222.132.78
Old 25-04-2011, 12:38 PM
Thats why we have a box of both on hand
ex22, grease, hitachi, nipple
