  #11   IP: 2.99.228.161
Old 22-09-2014, 11:12 PM
Default Re: Engcon tilty details needed
Originally Posted by Bucket on wheels View Post
Hi AusDave
it is possible to change the quick coupler, but it will mean that you will change the whole bottom rotating part and that may set you back some thousand pounds, so it might be cheaper to change the buckets quick couplings
if you contact these guys
http://www.jccengcongroup.com/
they can make a search on the serial number M13005
and then they can tell you how old is it and what control system it was delivered with, and what kind of quick coupling it has, and also give you a price for changing to another quick coupling system.
Ps: don't buy this machine with a tilty,
you will get way too much work
you will get Too many people around you with eyes popping out and jawbones falling down on their chests
you will get so in love with it, that you will cry every time you put your ass in the seat off a machine that doesn't have it
With posts like this its hard to resist temptation. I may just find myself locked out in the evenings. Not yet any rate but its one to watch
  #12   IP: 86.142.29.105
Old 22-09-2014, 11:26 PM
Originally Posted by AtlasRob View Post
My understanding from a bit of experienced gained last week, and I do stand to be corrected on any of this.
That model in the picture would appear to be pinned on.
I believe different bosses and shims will allow that to fit, 60, 65, 70, 80mm machine size dippers, maybe even bigger. The EC20 is for the 16 -22t size carriers.
PUP stands for Pick up on Pins, some times referred to as a pin grabber, the 65 would suggest to me 65mm pins on the buckets etc. The A is possibly a reference for pin centres but I'm only guessing. Knowing how far ahead the Scandanavian countries are I would not be at all surprised to find a chart with A,B,C, and corresponding acceptable pin centres.
As for control systems that is another kettle of fish all together but something any prospective purchaser of a used unit needs to be aware of. You can easily spend several thousand pounds on a control system.
As for Ausdave, I can only guess it's an E20 unit with the letters referring to the type of bottom hitch. C@t do have some different pickups but what there reference details are I have no idea.
Rob, did you take a look at this one http://used.engcon.com/product/view/68
didn't know they were doing these too - this is cheap IMHDO
  #13   IP: 86.142.29.105
Old 22-09-2014, 11:30 PM
here yer go Mint - ready made for yours!!
  #14   IP: 86.142.29.105
Old 23-09-2014, 01:45 AM
Originally Posted by AusDave View Post
Thanks for the replies everyone.
Here's a the best pic with the engcon I can get at present.
Attachment 22770
Not to keen on the bucket attachment system, would prefer standard pin grabber type. Is it a big deal to change the bucket attachment gear on the engcon end? I know it's reasonably straightforward to put new ears on the bucket.
Question to Frank or anyone who knows, I think the serial number on the engcon is M13005. What would be the build date of this engcon and what other details are relevant to engcons made at this time?
Thanks again, AusDave
By a remarkable coincidence there's a tilty on Finn tonight Dave, with that same hitch - ignore the price - it's an auction starting bid !!
http://www.finn.no/finn/b2b/construc...ckthrough=true
  #15   IP: 2.103.81.172
Old 23-09-2014, 07:03 PM
Have you noticed the two pipes on the tilt rams................both at the top of the ram very slick
  #16   IP: 86.142.29.105
Old 23-09-2014, 10:47 PM
Multi stage rams Mog!!
I'd guess single acting too?
This one certainly must be, by the look of it.
God knows why so many ports/pipes on that one last night - Where's Niklas????
An' here's an Engcon with 'em both 'up top'!!
  #17   IP: 86.112.66.108
Old 24-09-2014, 06:33 AM
Attachment 22782
Attachment 22783
Mine are both up top but there is a well hidden pipe running down the ram behind the to rubber hoses
  #18   IP: 46.235.155.26
Old 03-10-2014, 01:48 PM
niklas niklas is offline
Multistage rams is correct and single acting to.
Tiltrotator, Proportional System specialist, Application
Engineer and
former Field Service Engineer.
  #19   IP: 81.135.134.187
Old 06-10-2014, 11:38 AM
here yer go Dave another yard stick for you - looks tidy too!
http://www.finn.no/finn/b2b/construc...nkode=52296211
3850 + VAT and shipping to uk - Ca 350-400 quid
Downside is the hitch set up, unless you run the B20 system
engcon, tilty
