  #1   IP: 41.33.47.60
Old 05-08-2016, 09:56 PM
Mowbs 30000 Mowbs 30000 is offline
Default JCB 801-4 one slow ram
Hi, I have a 1988 JCB 801-4 which recently burst a hydraulic hose to the boom ram. I had 2 new hoses made up by my tractor repair shop and replaced them myself (both hoses to the same ram), topped up the hydraulic oil (it's at the right level in the sight glass) and functioned the ram to bleed the air.
Ever since then that one ram is very slow. I've looked everywhere on the system and on the Internet but it seems it should be self bleeding.
My initial thoughts are the hoses that have been supplied are restricting the flow, maybe the wrong size ID? Would that even be possible because I don't see how they could crimp the wrong size of hose onto the correct size of BSP fitting and the OD seems to be the same as the other hoses.
Everything else has plenty of power and the digger can still move and lift itself no problem.
Does anyone have any suggestions as to what could be up with it or give me troubleshooting suggestions.
Thanks.
  #2   IP: 92.14.67.219
Old 05-08-2016, 10:03 PM
Default Re: JCB 801-4 one slow ram
Thanks.
The guy who made the hoses up my have over crimped one of the fittings therefore reducing flow or if he cuts the pipe with an abrasive cutter it my have rubber crud in the pipe also reducing flow
  #3   IP: 213.205.251.205
Old 05-08-2016, 10:04 PM
Check hose for fitting and hose id Check circuit from control valve to ram for debris like any pieces of hose that may have broken away internally and be blocking fittings or control valve and relief valves.
burst hose, jcb 801
