  #201   IP: 86.139.112.208
Old 25-04-2016, 12:17 AM
Default Re: DA Rail Thread
great pix as usual DA ...... keep'em coming
Like the funnel
  #202   IP: 86.187.171.74
Old 24-05-2016, 11:40 PM
APEarthworks APEarthworks is offline
Just read the whole lot, Great thread great pictures !
Where were you in 2012-2013 in SA ? Which mine site ?
Alex
Turning Mud Pies into Strawberry Tart!
  #203   IP: 122.150.127.208
Old 30-09-2016, 05:04 PM
DuckingAround DuckingAround is offline
apologies alex, not on much these days.
2012/13 i was building track in Kararra mine and then up to Port hedland for fmg Solomon T155 expansion project.
then SA Iron Knob re opening at Whyalla
DA
  #204   IP: 1.152.97.5
Old 20-11-2016, 06:42 AM
Like the funnel
Known as a "tremmie" Gra, it's supposed to stop the aggregate separating when in free fall if pouring over 2m deep we have to use it. Others are solid metre long sections you screw on to one another, we use them to pour the concrete under water if the hole is wet. The concrete goes to the bottom of the tremmie and pushes the water up and out with minimal mixing/deterioration of the concrete. Over pour it by a bit and it pushes all the crap out the top of the hole (in theory).
DA
  #205   IP: 86.182.78.212
Old 20-11-2016, 01:00 PM
DA
Very clever, simple, obvious when (if) you stop and think about it,
