  #1   IP: 81.178.208.22
Old 18-12-2016, 07:32 PM
Default Emergency work
This happened a few weeks back but
Got a call from my pal at the scrap yard to come and have a look at what has just happened
This looks better than when I first got there as the shear was 3' away from the boom till I pulled it back together so I could get it on the ground for removal
This is where it got pulled from
As you can see a fair lump this is one of them step up stools
This took a bit of heat to get back
But managed it with a bit of heat and a couple of blows with a 28lber
Cut a couple of gussets out of inch plate
And stuck them in along with a bit of extra welds here and there
Finished job waiting to be fitted
Started the job at 5.00pm and got finished by 10.00pm ready for another busy day cutting
As the last picture shows it's a fair lump nearly 5 tonnes and had to get it into the shed on an angle as it is too long to fit through the door
  #2   IP: 31.49.119.217
Old 18-12-2016, 07:57 PM
Default Re: Emergency work
As I said the other night .... makes that 'hop-up' look bloody small Mog ... and they ain't that small
That is some boss that
PS ... what's MinimaApp ?? piccy resizer??
  #3   IP: 81.178.208.22
Old 18-12-2016, 08:12 PM
Yes bit of a arse but at least can show what I've been up to
Still it's soon Christmas so my get the picture thing sorted
One thing about welding things together is (I know you know this but) it all has to line up when you've finished i.e. The two pins have to be square with each other and be the right offset to go back on the machine and not to shrink the boss too much👍
  #4   IP: 31.49.119.217
Old 18-12-2016, 08:25 PM
Still it's soon Christmas so may get the picture thing sorted
Aye ...... an' that heat thing's a bugger eh!! .... plenty of temporary bracing, where possible and sequential working required ..... as you too would know Boyo ..... nice lil' job to keep you warm of an evening though
as has been said before ...... "didn't say which Christmas"
  #5   IP: 159.253.162.138
Old 18-12-2016, 08:49 PM
Nice little job! I guess they were a bit over enthusiastic with the ripping rather then cutting.
