  #1   IP: 81.130.168.0
Old 14-05-2017, 08:23 AM
Zetor Ad Zetor Ad is offline
Default Painting a excavator
I have a excavator that needs a freshen up do you recommend using a primer, I have painted a couple of machines before and always used one but I've painted many counterweights without a primer just keying the old gloss and they've been fine, it has no rust just looks dull but beyond a t-cut it is a working machine so I'm not expecting a car finish.
Thanks ad
  #2   IP: 151.230.154.125
Old 14-05-2017, 11:48 AM
Default Re: Painting a excavator
if you have any rust spots rub them back and put rust killer on which acts as a primer give it a key and top coat it ive got good results with a sponge glosss roller if you dont want to do lots of masking up
  #3   IP: 151.228.139.78
Old 14-05-2017, 08:24 PM
topkit topkit is offline
I have painted several machines over the years including a very scabby Fermec 860 and New Holland Nh85 i dont even think they were primed at the factory the way the old paint came off, i use an angle grinder with a fibre disc which gets you back to shiney metal then i use a Zinc primer followed by a couple of coats of the machinre colour, my machines are outside all of the time and the painwork lasts very well. I will post a few before and after pictures when i get a chance.
  #4   IP: 31.49.119.206
Old 14-05-2017, 10:19 PM
Ol' fabricator's friend Mart ..... short pile and some practice .. be amazed at the finish achievable with that too .... have put some shiny shite on with a 4" roller over the years and waaaay better cover than a gun (unless it's an airless of course)
  #5   IP: 151.230.154.125
Old 14-05-2017, 11:14 PM
ive got an earlex gun that ive had for years its the bolloxjust plug in and go,no water splats from compressor and as quiet as a hair drier
  #6   IP: 31.49.119.206
Old 14-05-2017, 11:20 PM
ive got an earlex gun that ive had for years its the bollox just plug in and go,no water splats from compressor and as quiet as a hair drier
one o' these Mart ?.....
or one of these ?
Got a Wanner version of the above .... used to use it for wax oil ... brilliant thing, but never tried it for painting with
  #7   IP: 151.230.154.125
Old 14-05-2017, 11:29 PM
like the first but older,prob close to 20 yrs old now
  #8   IP: 31.49.119.206
Old 14-05-2017, 11:39 PM
Ah right ..... not tried one of those ...... bit like a HVLP unit, 'cept it has it's own air supply
I've an airless unit which is excellent ..... for big areas, it's a faff to set up/clean ..... but hell it puts it on though
bit like this one ......
but can't recall the name of it ATM to find a pic
Water pistol for paint and don't they ever get through a 25 ltr pail
Great for painting buildings, steel work, boats, or containers !!
  #9   IP: 151.230.154.125
Old 14-05-2017, 11:47 PM
on the newer ones like ive got you can get a back pack that holds 5 ltr for bigger areas and there not big money will spray emulsion,gloss,fence paint,enamel etc fully adjustable paint flow on the gun as well i find it best not to allow to much paint through and go over it more avoids runs and the earlex blows warm air so dries very quickly
  #10   IP: 31.49.119.206
Old 14-05-2017, 11:50 PM
Hmm ..... sounds an interesting unit .... must have a look into those .... thanks
