  #1   IP: 82.132.231.146
Old 16-05-2017, 02:40 PM
volbar1 volbar1 is offline
Default Rod failure
Had the rod snap inside the dipper ram of my 30t excavator the other day, not had anything like that happen before, bit at a loss to see how it happened as the machine hasn't been miss treated or the dipper being contantly banged against the end of stroke but it has done 12000 hours.
I don't know if anyone can see from the picture if it was a manufacturing defect? The top 1/3 of the rod end where there are lines visible is really smooth and the other 2/3rd's is jagged, to me it looks like the jagged bit was holding it all together?Studio_20170516_143837.jpg
  #2   IP: 81.147.99.180
Old 16-05-2017, 04:19 PM
Default Re: Rod failure
Looks like a floor in it.
Could of just been a crack slowly getting deeper and deeper until the rest couldn't take the pressure any more...
But I know bugger all about metal and stress
  #3   IP: 213.78.124.22
Old 16-05-2017, 05:01 PM
EngconUK's Avatar
EngconUK EngconUK is offline
That looks like a standard case of crack propagation. The crack is likely to have started at the 1.30 o'clock position for whatever reason and gradually it opens up with repeated cycling to the point where the remaining material cannot withstand the stress and fails catastrophically. The crack area is relatively smooth because it's been rubbing over the years whereas the break portion has not. Not able to say what caused it - it looks as if you have a dent on the outer ring in the same place but that may just be coincidental.
My opinions, not Engcon's - it's just that I studied Metallurgy and Engineering at Uni too many years ago
Robert
  #4   IP: 82.132.228.226
Old 16-05-2017, 06:53 PM
Thank you Hilux, Robert. The damage around the outer ring was caused when the rod broke out from the cylinder, was suprised how slowly it pulled itself apart, bit of a brown trousers moment though!
  #5   IP: 31.49.119.206
Old 16-05-2017, 07:49 PM
I take it that is right at the shoulder of the machined part of the rod that the piston is screwed onto? ..... the end of the thread ??
as said a crack has propagated from that stress point, where the cutting tool, (creating the thread, has been withdrawn from the cut) and over the years, has rubbed smooth through use ... the rest has just given up the un-ending struggle to do what it should all have been doing, full time !!
bet that was a WTF moment, when the dipper started doing its own thing
IMHDO of course
apologies for adulterating yer pic
  #6   IP: 82.132.229.54
Old 16-05-2017, 09:32 PM
Hello Druid, yes that was the end of thread area👍
your not wrong about the wtf moment, I did go cold at the thought that a few days before I had 3.5t concrete panels hanging of the end of the arm, I dont think the cab would stop that coming very well!!
  #7   IP: 81.147.99.180
Old 16-05-2017, 10:00 PM
Would you compare it to a tree and say it's opened up the crack 17times?
  #8   IP: 31.49.119.206
Old 16-05-2017, 10:17 PM
Originally Posted by volbar1 View Post
Hello Druid, yes that was the end of thread area��
think I'd have pushed the right stick through the windscreen ..... if I had the time
I'd say that the termination of the thread had set up a stress point in the rod ..... dare say that anyone losing a piston off their dipper rod would find a similar break point ..... other rods are mostly under compression when most highly stressed on 360 M/cs
It's why, when turning, if a diameter change is required, the corner of the step is left radiused slightly ... if possible, to relieve the stress point caused/set up by the change in diameter
http://www.amesweb.info/StressConcen...derFillet.aspx
" Stress Concentration Factor: Dimensional changes and discontinuities of a member in a loaded structure causes variations of stress and high stresses concentrate near these dimensional changes "
  #9   IP: 86.158.217.11
Old 16-05-2017, 10:20 PM
You'd of made it worse
  #10   IP: 31.49.119.206
Old 16-05-2017, 10:22 PM
how would dropping the boom possibly have made it worse Rory
