Go Back   The British Construction Equipment Forum > INDUSTRY MATTERS > Industry Chat
  #31   IP: 92.30.29.91
Old 25-05-2016, 08:20 AM
Default Re: buying grease, whos cheapest?
JCB blue is EP2, right?
Is it as good as generic moly grease for pins and bushes or should I run two types of grease?
Ruben, it's what's known as lithium complex EP2. The moly is the correct grease really, because of it's resistance to loading characteristics, but for small machines the lithium will be fine. It wont last so long before pounding out. I have found one of the best underwater greases is a Total product called Ceran WR 2.
http://www.totalindustriallubricants..._-_04.2009.pdf
  #32   IP: 5.254.163.144
Old 25-05-2016, 08:27 AM
What in your opinion should I use in my brand new machine to keep it tight as possible? Money no object, it's not like I've a fleet to keep greased.
  #33   IP: 86.158.217.7
Old 25-05-2016, 08:50 AM
Use Moly for the Pins and EP2 for the Slew ring seems to work on my machines.
  #34   IP: 92.30.29.91
Old 25-05-2016, 08:56 AM
All plain pins and bushings use Molybdenum and for bearings use Lithium EP 2 or lithium complex EP2.
  #35   IP: 5.254.163.144
Old 25-05-2016, 09:11 AM
Spot on, cheers.
That Moly sticks like shit to a blanket, I've used it inside air rifle pistons before.
  #36   IP: 82.132.219.102
Old 25-05-2016, 01:05 PM
liamkav's Avatar
liamkav liamkav is offline
Called HPS today they want 1.75 for ep2 and 2.45 for Molly both are plus vat.
  #37   IP: 178.16.3.38
Old 25-05-2016, 06:38 PM
Casedriver's Avatar
Casedriver Casedriver is offline
JCB Blue is 2 a tube for a box or 4 boxes for price of 3 round here at the min and Ambra EP2 is 2.55 a tube
Take the Bull by the Horns and Ride
  #38   IP: 78.150.9.65
Old 30-05-2016, 07:23 AM
charlie2 charlie2 is offline
i use jcb blue grease seems to stay in bushes etc well may not be cheapest but when you do have to pull a pin out they allways look well lubed, fairly often the jcb dealers have promotions on whole cartons/boxs.
  #39   IP: 95.147.72.91
Old 30-05-2016, 09:33 AM
Cheggars Cheggars is offline
Who actually makes the grease for Jcb.
I know Morris oils make the lubricants for massey, fendt and valtra.
  #40   IP: 86.182.91.235
Old 30-05-2016, 11:02 AM
I need to do some checking as rule of thumb in my memory Shell Gadus EP 2 costs me 2 tube used it Propshaft, slewring & Engcon.
3% moly used in autolube, steering joints, rear blade etc is 3 tube.
NLGI 2 Kernite breaker grease was about 3.50 -4 tube iirc bought several boxes years ago and only just about finished it.
cheapest, ep2, grease, lowest, price
