  #1   IP: 86.214.251.169
Old 23-01-2017, 08:26 PM
Default Stump Removal
Is a ripper the best tool for stumps ?can you prise against the back of the ripper like you can with a bucket ?
I have always just used the narrow bucket - but I am needing to remove stumps more and more often as I manage to pick up forestry work .....is a ripper significantly quicker and easier on the machine ?
Cheers for any advice
  #2   IP: 81.158.75.97
Old 23-01-2017, 08:54 PM
Default Re: Stump Removal
We have a tool for the job
  #3   IP: 86.214.251.169
Old 23-01-2017, 08:57 PM
Drumroll.......
  #4   IP: 86.155.107.149
Old 24-01-2017, 12:50 AM
best way is ripper and bucket both as a combo, dig round stump best you can with a bucket, then swap to ripper and bust out as many roots as you can, then back to bucket to pull stump and tap root.
theres a knife like tool that will chip away at roots but like a grinder it leaves a lot of it in the ground
  #5   IP: 148.252.128.16
Old 24-01-2017, 12:57 AM
Drumroll.......
Anti climax I'm afraid, cant seem to find a picture. it's basically a sharp ripper with a sharp foot to cut away at the stump
I'll have another look tomorrow
  #6   IP: 88.109.146.240
Old 24-01-2017, 01:25 AM
muckyman muckyman is offline
Cant beat a hawkfork for stumps but best thing is leave 6 foot of stump on rather than cutting at the base makes a great lever
  #7   IP: 86.139.115.77
Old 24-01-2017, 01:27 AM
not the exact one I was thinking of, but similar ...... like this Aiden?
https://youtu.be/gSEdeJ37-ko
  #8   IP: 86.214.251.169
Old 24-01-2017, 07:59 AM
Hawkfork ? Ill have a google.
If its an odd one for a customer we might leave a bit as lever but these are harvested so thats not an option
Re a knife type setup...... I cant leave anything in ground as it is where tracks are going and usually cut and fill.
  #9   IP: 86.139.115.77
Old 24-01-2017, 11:32 AM
another version taking no prisoners Boyo
https://youtu.be/pvPoTnvdFP0
looks the biz
  #10   IP: 81.158.75.97
Old 24-01-2017, 11:33 AM
Got touch now.... ours is similar to the second one Graham put up.
