  #1   IP: 86.153.6.246
Old 16-03-2018, 09:31 PM
Default Gear pump v piston pump
Which is best, and why?
  #2   IP: 92.14.252.163
Old 16-03-2018, 10:26 PM
Default Re: Gear pump v piston pump
Gear pump is simpler fixed flow pump. Piston is more complex with variable flow etc, load sensing etc.
Both have there place
  #3   IP: 109.152.18.170
Old 16-03-2018, 10:33 PM
For what application?
  #4   IP: 86.153.6.246
Old 16-03-2018, 10:52 PM
Just been looking at mini specs, and one manufacturer gives a choice
  #5   IP: 86.153.6.246
Old 16-03-2018, 10:54 PM
So on a mini, the gear pump is going to be the budget option?
  #6   IP: 109.152.18.170
Old 16-03-2018, 10:57 PM
Gear pump will do the job, Variable piston pump will be smoother and perform better, imo. Iíd go Variable every time.
  #7   IP: 81.157.198.72
Old 17-03-2018, 12:53 AM
Gearpumps are simple cheap and reliable.... Most basic pump and basically the faster it turns the more Flow/Power you get.
Variable pumps can give the same Flow/Power (within reason) through a entire rev band.
  #8   IP: 188.220.6.135
Old 17-03-2018, 06:04 PM
Davejcb Davejcb is offline
How about adding open or closed centre pumps into the equation?
  #9   IP: 92.14.252.163
Old 17-03-2018, 07:24 PM
Gear pumps will be on an open centre hydraulic system. The gear pump will be pumping oil as soon as the engine starts so it needs to go some where when no fuction is used so it returns through the open circuit to the tank. Closed circuit will only start to pump when a function is operated.
You will get better flow Sharing with piston pumps etc
  #10   IP: 92.14.69.104
Old 17-03-2018, 09:01 PM
Iíd have a piston swash plate pump over a gear pump, for a start they donít wear as fast plus more economical to run as adian said a gear pump is pumping all the time,where a piston pump swashes to neutral when there is no demand so no load on the engine
Iíve made a few hydraulic power packs for different things and one with a gear pump on used to get a lot hotter and used more fuel than the piston pump ones
