  #1   IP: 31.105.232.46
Old 23-05-2018, 12:10 PM
Zetor Ad Zetor Ad is offline
Default Case CX 130A heavy leavers
Hi I purchased a 07 cx130 a last year, itís a gem of a machine but I find the leavers heavy compared to my other excavators especially when Iím working it long hours is this normal for this machine and can it be modified/repaired
Any help will be appreciated 👍
  #2   IP: 109.152.21.154
Old 24-05-2018, 06:03 AM
Default Re: Case CX 130A heavy leavers
No idea if itís normal for that machine.
But probably all you can do is check the servo pressure is correct and make sure the servo filter/filters have been changed. And possibly that the servo accumulator is still functioning, although I donít think this would cause heavy operation if it were not doing its job, but worth a try, you never know.
  #3   IP: 213.205.242.188
Old 24-05-2018, 06:53 AM
No idea if it’s normal for that machine.
But probably all you can do is check the servo pressure is correct and make sure the servo filter/filters have been changed. And possibly that the servo accumulator is still functioning, although I don’t think this would cause heavy operation if it were not doing its job, but worth a try, you never know.
Had the same thing on my machine after a couple of thousand hours, just a slight adjustment of the servo pressure cured it, it's something you can do yourself and only takes a coupe of minutes.
  #4   IP: 86.132.248.59
Old 25-05-2018, 08:54 PM
Thanks Iíll try that I just canít remember how😬
  #5   IP: 178.102.33.184
Old 25-05-2018, 09:51 PM
If I could upload pics🤔 I'd show you what it looks like on my machine, there's basically a 22mm dust cap that you take off to reveal a locking nut, locking off an alan key adjuster, slacken the locking nut, then just unscrew it a fraction of a turn then lock it back off again, and see if that makes any difference, it is only a fraction at a time, you'll know if it's to much cos they will be really light, it's just a case fine tuning it to how it suits you.
  #6   IP: 109.146.120.232
Old 25-05-2018, 10:11 PM
the pressure relief valve will probably be on the servo circuit control solenoid valve block - feeds your servo circuit with pressure and is controlled by the dead man switch ... should look pretty much like most other PRVs .. setting screw with a lock nut securing it and maybe a cover over it
  #7   IP: 86.138.112.199
Old 26-05-2018, 06:35 PM
Thanks, Iíve sent you a private message 👍
