  #1   IP: 81.153.239.134
Old 06-08-2018, 09:24 PM
Default Blade droop
Brother in laws 2.6t Volvo mini: the blade slowly drops. Hes put new seals in the ram, but it still slowly drops. Whats the likely cause please? Could it be seals in the spool?
  #2   IP: 92.14.252.163
Old 06-08-2018, 09:29 PM
Default Re: Blade droop
Quite possibly seals in the slew joint. Best way to check would be to blank the top side of the slew joint off and see if it drops then.
  #3   IP: 81.153.239.134
Old 07-08-2018, 07:22 AM
Thanks Aiden.
  #4   IP: 78.189.229.83
Old 07-08-2018, 12:42 PM
Hi,
Is the o-ring installed between the rod and the piston. I've been caught out by this once. The blade would hold the machine up all day but when you lifted the blade up it slowly dropped to the floor. The oil pressure on the piston side must of been enough to hold the piston tight against the shoulder on the rod when lifting the machine up.
  #5   IP: 81.155.105.111
Old 07-08-2018, 06:40 PM
diggerman's Avatar
diggerman diggerman is offline
Every volvo Ive had allways slews boom to the right on the ofsett very slowly.thats on 2 ec15bxtv an ec18c and now an ecr25d.bit annoying but not a problem
Nick...
  #6   IP: 109.153.114.21
Old 07-08-2018, 10:12 PM
Originally Posted by diggerman View Post
Every volvo I’ve had allways slews boom to the right on the ofsett very slowly.thats on 2 ec15bxtv an ec18c and now an ecr25d.bit annoying but not a problem
Nick...
how curious
is it on a changeover / 6 x 2 way valve from slew? or on the foot ?
