  #1   IP: 75.158.164.6
Old 02-01-2014, 03:17 PM
candrill.chad candrill.chad is offline
Default Kubota RG60 Parts
I have a 2000 Kubota RG60. What I would call the track drive ECM went on it. Wondering if anyone out there can provide any assistance on where to find parts for these things.
I heard that the Mitsubishi LD400 is very similar and may even share parts, however I have still not found any one that sells anything.
Info on the part:
Canycom
Model SE11501
MFG No. 4S0032
ROM No. 4SE100
Chikusui Canycom Inc.
Made in Japan
  #2   IP: 95.144.164.167
Old 02-01-2014, 03:26 PM
Default Re: Kubota RG60 Parts
I doubt it will be good news if it has? I'm assuming you mean the ECU type unit in front of the drivers feet on the right?
This is always the worry with this type of control for tracked dumpers?
How have you established it's actually gone? When we had issues it turned out nothing more than damp connections, which we made the mistake of using WD40 on?
A simple clean up with 'contact cleaner' had everything sorted?
I'd give Alisdair at A.R.M Machinery a call, or if you really want to have a bad day call Cautrac!!!
  #3   IP: 75.158.164.6
Old 02-01-2014, 04:58 PM
Unfortunate, it is confirmed, that the brain box is done. Thanks for the info and I will contact them and hopefully get this thing up and running. An exhaust company did some welding on it, thinking there is no electronics to be harmed...
  #4   IP: 109.153.224.164
Old 02-01-2014, 05:03 PM
would be a good idea to find ECU repairs ,testers in your area ,also would pay to check connections /earths first
  #5   IP: 86.180.114.0
Old 02-01-2014, 06:37 PM
Computers
Why put such crap on a dumper
  #6   IP: 95.144.164.167
Old 02-01-2014, 08:09 PM
Computers
Absolutely PD, It would be a major influence if I were purchasing and to be perfectly honest having used both, the simple 2 lever setup gives better control.
I'll be very interested to know the cost of the ECU unit in this instance as both Neils RG60 and Greg's LD400 use this setup.
  #7   IP: 87.112.23.219
Old 02-01-2014, 08:42 PM
jmsport101 jmsport101 is offline
Maybe worth trying a Candycom dealer too?
  #8   IP: 86.144.235.12
Old 02-01-2014, 09:27 PM
Must admit in all the posts I've ever posted on any forum I have NEVER felt the need to add tags
  #9   IP: 78.148.68.125
Old 03-01-2014, 01:43 AM
muckyman muckyman is offline
Wish i could change my brain box
  #10   IP: 86.154.21.102
Old 03-01-2014, 03:31 PM
Someone posted on here a while back that they have a 'tame' ECU repairer,
IIRC 'bout sept./oct time.
Could have been Ollie or Vin and on one of the 'major' threads, in response to, again IIRC, comments I had made in regard to the costs of buying any older m/c with them on, like JSs, etc..
Racking my brain I think it was on Ollie's thread as the poster said that the 'leccy wizard' had subsequently been doing a lot of work for his dealers on boxes.
canycom, kubota, mitsubishi, parts, rg60
