Go Back   The British Construction Equipment Forum > EQUIPMENT > Useful Technical Info and Reference Documents
  #21   IP: 2.97.235.52
Old 03-01-2015, 09:26 PM
Traxcavator.'s Avatar
Traxcavator. Traxcavator. is offline
Default Re: Tips and Tricks
Two spanners together ..... utter bodgery and to be avoided at all costs !!
Your man was obviously well trained thats why he may never have heard of the method. Now he does it all the time he has slid well down the ladder.
Though I have to admit I have used the method ......
  #22   IP: 89.242.40.208
Old 03-01-2015, 10:46 PM
diggerjones's Avatar
diggerjones diggerjones is offline
Oil heating tank full of heating oil is weeping from the seems a vertical seem where the 2 halves meet.
What house hold substance will cure the leak temporarily????
  #23   IP: 94.194.14.72
Old 03-01-2015, 11:14 PM
Richard_S Richard_S is offline
Soap?
If you want to open an internet link in a new tab, press the wheel on the mouse
  #24   IP: 94.197.120.249
Old 03-01-2015, 11:19 PM
delbouy delbouy is offline
If it's a plastic tank, can you not use a soldering iron on it and plastic weld( melt ) it together as a temperery fix?.
  #25   IP: 89.242.40.208
Old 03-01-2015, 11:31 PM
Originally Posted by Richard_S View Post
Soap?
Correct, that didn't take long
  #26   IP: 31.185.169.238
Old 04-01-2015, 12:01 AM
modelman093's Avatar
modelman093 modelman093 is offline
Originally Posted by V8Druid View Post
An' if that don't shift it, provided you can get at it, a small sharp cold chisel in the centre of one of the nut's flats, in line with the bolt and a good sharp whack.
Expands the dia. of the nut slightly and will often be enough to make the difference between yay, or nay!!
Oh an' plenty of Plusgas/WD40/whatever it's called where you are!
.................... an' if that don't do it - a 2mm arc rod run along the chisel mark and get swinging on the spanner before the nut cools.
obviously the bigger the nut, the bigger the chisel/rod!
The nut's almost certainly nadgered by now, so you can repeat it on all flats if necessary, or just split it, either with a cold chisel, or a hydraulic nut splitter...........if you can get the damned thing in there, as it will almost always have come under Sod's jurisdiction and there's just not quite enough room
Drilling through the nut parallel to the stud or bolt makes it easier to expand or split.
  #27   IP: 2.97.235.52
Old 04-01-2015, 08:14 AM
Originally Posted by Hookedondiesel View Post
Oh yes, the kind you put in the girls hair in front of you, at school.
Are you sure that was glue ....
  #28   IP: 74.14.36.166
Old 04-01-2015, 12:52 PM
Hookedondiesel Hookedondiesel is offline
LOL
1994 JCB 210S 4x4x4
  #29   IP: 94.197.120.249
Old 04-01-2015, 03:56 PM
Well it was defo white sticky stuff, u er!!!!
  #30   IP: 86.138.25.195
Old 04-01-2015, 06:22 PM
Davejcb Davejcb is offline
A new tank ASAP... That's the last thing you want splitting in half!
One my tyre fitted does, if a new tyre isn't sealing onto the rim he puts a ratchet strap all the way around it , which squishes it into the rim..
