  #1   IP: 86.173.119.56
Old 19-06-2016, 12:40 PM
Default Hino 7.5 tonner?
Any good?
HINO 300 SERIES 4009cc 76k km
One in local auction on Tuesday were running an iveco at the moment but it body height is high and with a 3m edge 3.6m centre arch bridge to get to our yard and farm height is critical the hino looks lower,
I've heard parts are expensive?
There is also 2 x man which we might have a go at as used to run a man before iveco and preferred it to the iveco.
MAN TGL 8.154 4X2 - 4580cc 197k km and 126k km
  #2   IP: 86.158.218.181
Old 19-06-2016, 12:47 PM
Default Re: Hino 7.5 tonner?
Hinos are very good under rated lorries from what I've heard, Local firm runs around 6, 6 leggers alongside Dafs and a couple Renaults. Sort of firm that would not have them if they where not worth having. Never seen a little one in the UK before but see them in Auz and third world country's performing.
Parts will most likely be similar priced to anything else, particularly if using the likes of All Spares etc.
  #3   IP: 86.173.119.56
Old 19-06-2016, 12:57 PM
Just having a look they come with dual airbags and stability control and a decent Bluetooth radio etc which is rare in 7.5 tippers.
  #4   IP: 31.215.241.55
Old 19-06-2016, 01:13 PM
conorcx130's Avatar
conorcx130 conorcx130 is offline
They are basically a big Toyota dyna aren't they? Which if that's anything to go by should be a reliable truck. I personally wouldn't have any issues buying one, I know there's a lot of lads at home running bigger hinos since the 80s and swear by them.
  #5   IP: 86.113.248.150
Old 19-06-2016, 02:01 PM
Is it body size your looking for as those Isuzu's are smaller but carry same as the bigger 7.5 tonner
  #6   IP: 86.130.166.200
Old 19-06-2016, 02:15 PM
breaks were always a let down on those types , still vacuum over hydraulic ?
  #7   IP: 86.173.119.56
Old 19-06-2016, 03:15 PM
http://www.hino.ie/assets/815_4x2%20rigid.pdf
Reading that yep you're right graham
  #8   IP: 86.187.164.139
Old 19-06-2016, 03:31 PM
APEarthworks APEarthworks is offline
Company I used to work for in Oz had 3 Hinos 2 X 6x4 tippers and a 4x2 tipper great little trucks only problems we had was aircons but that was in Darwin NT in 39' + heat and humidity
Alex
Turning Mud Pies into Strawberry Tart!
  #9   IP: 109.152.95.211
Old 21-06-2016, 10:59 PM
Dad said the hino didn't look man enough so he bought the man instead, auto box in it be new experience
