  #1   IP: 86.7.227.133
Old 03-01-2017, 07:56 PM
Default 3.5t tow vehicles
looks like might be changing from the l200 for towing upto 3.5t so far it looks like im after an auto 3.2 ranger from 2014 onwards.
So beside the ranger what else tows 3.5t i know the latest shape d max and navara will but what other options are out there needs to be able to seat 5 as sometimes use the vehicle at weekends
  #2   IP: 81.147.97.203
Old 03-01-2017, 08:02 PM
Default Re: 3.5t tow vehicles
New hilux, if you want to spend that much. I think l200 is about 3t now.
Do you need a pick up? Otherwise its landcruiser, range rover, disco.
  #3   IP: 86.7.227.133
Old 03-01-2017, 08:19 PM
Carry tools and stuff in the back so would rather keep everything separate rather than a big open space with all the kit stinking the van out. Panel van with rear seats and steel bulkhead might be handy but don't think they do one with the towing capacity. When worked for lor we had a 110 defender would never own one hateful thing
New l200 is 3.2t
  #4   IP: 86.132.75.151
Old 03-01-2017, 08:22 PM
pettsy pettsy is offline
Iveco double cabs used to be able to tow 3.5t, not sure if newer ones can? Do you need a 4x4? Just looked online and apparently new transits can tow 3.5t with a reinforced trailer coupling fitted, do they do a crew van?
  #5   IP: 81.147.97.203
Old 03-01-2017, 08:34 PM
Yes most ivecos can tow 3.5t. Vans were some times lighter but if you got a twin wheel then they usually are 3.5t
  #6   IP: 86.7.227.133
Old 03-01-2017, 08:51 PM
just had a look for an iveco bit basic inside but the only ones ive seen so far are lwb and are really too long
  #7   IP: 86.158.219.100
Old 03-01-2017, 08:54 PM
I loved my 2.3 5 speed Iveco Daily.... aside from the fact the 2.3 engine and 5 speed box where a hateful combination when towing up the local hills and you would either stall or spin out when hillstarting with 7t train weight.... Aside from that it was hell of a tool
  #8   IP: 86.7.227.133
Old 03-01-2017, 08:57 PM
thats why im leaning to a pick up again plus the rangers auto box is meant to be great with the 3.2 and mainly cant be arsed with having to either change down on long climbs (not a massive problem) or having to slip the clutch when a loaded trailer is on for hill starts
  #9   IP: 31.185.213.2
Old 03-01-2017, 09:03 PM
I have a ranger 3.2 auto and it is the best work pickup I've had. Pulls well, great with a full trailer. Done about 40,000 miles so far, mostly pulling at least 3t. Would never go back to a defender.
Also own an Isuzu D-Max manual, but find it uncomfortable. Pulls well, but is a bit high geared for towing 3.5t. Lot of clutch slipping to get away and top gear too high.
  #10   IP: 31.185.213.2
Old 03-01-2017, 09:06 PM
Trouble with transits and most other full sized vans is when you use them outside work and want to park. Can get in parking spaces, but can't open the doors as too wide.
