  #21   IP: 86.144.92.239
Old 02-05-2010, 09:50 PM
Guest1 Guest1 is offline
Default Re: C@t TH560B forklift problem!
May be cheaper to buy another lift truck by the sound of it
  #22   IP: 95.149.42.140
Old 02-05-2010, 10:01 PM
diggerhayne's Avatar
diggerhayne diggerhayne is offline
Location: if my partner had her way down the field with bigdog
eeyore your still about then the old 62s and 63s suffered abit with seal problems but that was useally the wrong fliud i think,these newer cats have not been good at allmate of mine has 3 its a wunder he hasant killed the rep who sold them to him, they have been that good i have just sold my cat 62 to buy a 13mt manitou,
  #23   IP: 90.196.146.94
Old 02-05-2010, 10:13 PM
AtlasRob's Avatar
AtlasRob AtlasRob is offline
You could well be right there. I have no idea what the guts of this axle will look like. When told the diagnosis I had to go and look at the axle as I could not imagine it to be true
Originally Posted by diggerhayne View Post
eeyore your still about then..............these newer cats have not been good at all........... just sold my cat 62 to buy a 13mt manitou,
Still hanging in there DH. I didnt realise these machines had such a bad history. I played a bit on one many years ago and quite liked it but didnt have to maintain or service it
Had the joy of loading an artic on Thursday using a Manitou, cant say I felt comfortable, the levers just seem all over the place.
If their no good in the seat, put them on their feet
Rotation excavation across the Nation.
  #24   IP: 95.149.42.140
Old 02-05-2010, 10:21 PM
out of choice i would have a cat 63 but the manitou came along at the right price,its in good nick we want reach and stability its got chassie leveling so job done
  #25   IP: 86.156.226.95
Old 02-05-2010, 10:44 PM
cps140's Avatar
cps140 cps140 is online now
Not that big of a job if its the same as the manitou i did a few months back! Yea drop the axle out and split the casing at both sides of the diff housing! seals are most likely just o-rings!
fluid im guessing should be LHM but i would check that with cat!
  #26   IP: 195.93.21.65
Old 03-05-2010, 01:05 AM
Traxcavator.'s Avatar
Traxcavator. Traxcavator. is offline
Just like a Tractor. Not a big deal, just the usual care when installing. Most brake systems like this can be pressure checked before the axle is refitted. Was a simple problem. I must admit i didn't think of the brake issue.
Jumping the gun is never a wise move ......
  #27   IP: 90.196.146.94
Old 03-05-2010, 08:13 AM
AtlasRob's Avatar
Thanks for the comments and replys guys.
I am not likely to be asked and definetely wont be offering to do the repair .
Educational though from my point of view as I have not encountered this set up before. Heard it mentioned lots of times just never engaged the brain as to what it actually meant
I believe the off the cuff quote was about 2k to do the job. I cant make a fair comment as the only axle I ever split was on the duck when we changed the centre housing. That took me and the fitter best part of 3/4 of a day, and no parts cost.
If its only O rings I would say its expensive, but for an off the cuff quote I suppose allowance has to be made that it could be worse than O rings.
And I do believe there was a comment about it being pressure tested afterwards. Thanks.
  #28   IP: 95.149.42.140
Old 03-05-2010, 08:34 AM
dont get me wrong, the 62 63 83 were on the whole were good machines brake and diff faults were all some suffered with,but they would give no other trouble,the newer ones are not good at all
  #29   IP: 195.93.21.65
Old 03-05-2010, 08:47 AM
That's sadly the case with many brands these days. Its wrong to skimp on the metalwork. People aren't stupid. Next buy could well be a different brand.
