  #21   IP: 195.93.21.41
Old 17-02-2010, 10:17 AM
Traxcavator.'s Avatar
Traxcavator. Traxcavator. is offline
Default Re: D6M 3116 eng
Hi mate, Morning !! I put it down to internal corrosion. Diesels should allways be run with inhibitor, as we run our machines with antifreeze all year round we dont have these oxidation corrosion problems. The leak waws from the water jacket near the base of No 2 cylinder and into the oil gallery that that predominantly feeds the camshaft bearings.
Jumping the gun is never a wise move ......
  #22   IP: 124.185.103.240
Old 17-02-2010, 10:30 AM
ianoz. ianoz. is offline
Hi Traxs , Good to hear you were able to get another block .A reasonably Big job ahead to swap every thing over ?.I suppose the 6 was supposed to be out on a job ,Not parked in a shed with problems . Ian .
  #23   IP: 195.93.21.41
Old 17-02-2010, 10:37 AM
I would love it to be out on a job mate but we have a wet winter now the snow has gone. We run a traditional muckshifting business and are used to a few months shut down. Some years we plow on through, depends on the work we are doing.
  #24   IP: 124.185.103.240
Old 17-02-2010, 11:02 AM
Hi Traxs Traditional means nothing to an Aussie.And our winter .{where I am Anyway } I work in short sleeves shirt and shorts ,all year round . Occasionaly put a coat on in the moring ,but its usually off within an hour ..On construction sites ,workers are made wear longs .Which is why i stick to working for small builders .No Stupid rules ,just common sense ..Ian .
  #25   IP: 195.93.21.41
Old 17-02-2010, 11:20 AM
Basically with the Big outfits, first heavy rains in october usually means shut down until the beggining of April. We don't work like that and we do get other types of work, site clearing, demolition, gravel hauling, ditch and river work etc. However we do allow and are prepared for a winter shut down.
  #26   IP: 124.185.103.240
Old 17-02-2010, 11:47 AM
sO wHAT DO THE WORKERS OF THE BIG FIRMS DO FOR 5 MONTHS ? STARVE??? .Ian .
  #27   IP: 195.93.21.41
Old 17-02-2010, 11:53 AM
To clock up the hours they used to work 7 to 7 seven days a week. every fouth weekend they would knock off friday lunch time for a weekend then back to work Monday lunch. Most of them had other part time jobs. It does not happen so much now but you can't work soils in the wet !! .Bob would be a good guy to ask more.
