  #1   IP: 195.93.21.70
Old 09-01-2010, 11:16 AM
Default D6M 3116 eng
Do any of you guys have D6M's on the fleet. I know you do Roly,
My question is have you had problems with oil getting into the cooling system.
We have fitted a new oil cooler gaskets and seals and despite being told it probaly wasn't the head i removed it and had it tested and reconditioned, nothing was found to indicate the cause of the problem......any ideas ?
  #2   IP: 195.93.21.66
Old 09-01-2010, 11:30 AM
Default Re: D6M 3116 eng
The tractor in question berfore its troubles.
  #3   IP: 95.148.130.24
Old 09-01-2010, 12:27 PM
RolyD8k RolyD8k is offline
Trax,we have never had that problem with oil in the water,but we
have diesel due to a cracked injector seat,after testing we had to
fit another head,i dont think oil can contact with water only via the
head or oil cooler but i will ask the question.
  #4   IP: 86.144.91.125
Old 09-01-2010, 01:18 PM
Guest1 Guest1 is offline
Had that problem with a uk coal cat 950 wheel loader.Deasel in the water must be fairly common problem.
  #5   IP: 90.193.135.221
Old 09-01-2010, 05:09 PM
......... despite being told it probaly wasn't the head i removed it and had it tested and reconditioned, nothing was found to indicate the cause of the problem......any ideas ?
Sorry I cant help but I am facinated to know, did that cure it ?
There isnt much worse than curing a problem but not being sure how you cured it. It always nags that it might return if you dont know why!.
  #6   IP: 88.109.139.90
Old 09-01-2010, 05:40 PM
Richard's Avatar
Richard Richard is offline
This is probably way off base, but on the Ford tractor engine if it did that it was a porous casting somewhere in the cam-shaft gallery pushing to the water jacket
  #7   IP: 92.3.118.35
Old 09-01-2010, 05:58 PM
Rossco's Avatar
Rossco Rossco is offline
Give - is - the Serial Number fella ... First three digits will do ..
Ide say if the Oil coolers are cool then look at the water pump?
Global Warming is Everywhere
Iam looking at 2ft of the Stuff now
  #8   IP: 195.93.21.66
Old 09-01-2010, 07:09 PM
tctractors tctractors is offline
I think the Water pump is a nasty little Vee Belt driven job on these little tractors, I would tend to pull the Engine to bits to find what the snag is, it does sound like ether a gasket or O ring failed around the front case ?, normaly you would swear it to be the oil cooler or just behind???.
tctractors
  #9   IP: 95.149.42.219
Old 09-01-2010, 07:18 PM
diggerhayne's Avatar
diggerhayne diggerhayne is offline
Location: if my partner had her way down the field with bigdog
i had a 3116 in my crusher we got 6700 hrs out of it,i was told they were only good for 5000 hrs,the only thing we had in 8 yrs was it snapped a rocker,i had it rebuilt by slys nr peterbrough, they said it was a wunder we couldnt see the pistons going up and down it was so worn but it never burnt more than half a gallon of oil a day
  #10   IP: 90.193.135.221
Old 09-01-2010, 07:19 PM
There are few folk I have come across in my travels ( including hyperspace) that have a knack of cracking me up with the matter of fact, off the cuff comments, just like that.
You should seriously consider writting a book Tony, the other person is Koo you are definetly a very rare breed both in your experience and understatement of your talents. The real beauty is I dont think you even know you do it.
