  #1   IP: 90.193.135.82
Old 07-03-2010, 08:35 PM
Exclamation C@t TH560B forklift problem!
I only know the model as its written on the side.
What would make the front axle breather start putting oil out?
This machine is an 2004 by the plate and has arrived from a job in London, about 6000hrs from memory.
First thing I did was top the engine oil up, 2nd blow the tyres up, 3rd put it to work.
Seems fine with no major problems that a bloody good service wont put right.
The third time it was used, by another, he had unloaded some TVCB's and was tramping them about 100yds down the compound. I dont know how many trips he did, I did a full artic of 12 without problems, but at some point his banksman spotted an oil trail on the tarmac.
I have checked the hub oils, to level and not in too bad a condition.
Axle oil to level and black as coal.
Diff oil, to level and black as coal.
I didnt see the discharge and suspect a little goes a long way as none would appear to be missing and the colour would suggest is has not just been changed and overfilled?
Any suggestions, ideas?
  #2   IP: 195.93.21.65
Old 07-03-2010, 08:53 PM
Default Re: C@t TH560B forklift problem!
First thing that would spring to mind is overfill. Did he do a lot of high speed reversing ? Maybe the oil is to thin (viscosity ) wrong or just plain wore aht !!
  #3   IP: 90.193.135.82
Old 07-03-2010, 09:09 PM
I will ask him about the reversing. IMHO the oil is past its sell by date. How, why, does this lead to blow out? I have no experience with this sort of fault, so any guidance is greatly appreciated.
I have advised to keep using it, keep an eye on it and get it serviced.
  #4   IP: 195.93.21.65
Old 07-03-2010, 09:15 PM
Somtimes due to the position of the breather, reversing at prolonged speeds can force the oil out. The breather should be changed periodicaly too. If gear oil is overdue it turns to a thinner viscosity where as engine oil tends to sludge due to the carbon ingress.
  #5   IP: 95.150.138.38
Old 07-03-2010, 09:16 PM
Rob ,i had a similar problem on a new 3cx ,when roading for a distance 1 mile or so ,the rear axle used to get hot and it would chuck oil out of the breather ,in 250 hrs the oil looked like sump oil,the yellow colour of the axle even changed to a different shade ,jcb came out took oil samples and said keep an eye on it
i changed machines at 4500hrs and it was still the same
who knows what was wrong
cheers graham
  #6   IP: 90.193.135.82
Old 07-03-2010, 09:35 PM
Originally Posted by d4c24a View Post
Rob ,i had a similar problem on a new 3cx ,when roading for a distance 1 mile or so ....................
Thanks, Trax, I never thought about the breather being replacable, or the breakdown of the oil.
Did you have to add any oil to that back axle Graham? or is it as I suspect, a little making a big bloody mess
ON EDIT,
If he had been doing other jobs before unloading and then moving the TVCB's his axle would have naturally been hotter and the oil thinner than when I had used the machine. DING! thanks boys.
  #7   IP: 88.87.189.64
Old 07-03-2010, 10:03 PM
Stock..'s Avatar
Stock.. Stock.. is offline
Some of those sows gave grief with the diff's.
"Never underestimate the predictability of stupidity"......
Bullet Tooth Tony
  #8   IP: 90.193.135.82
Old 07-03-2010, 10:11 PM
A good question stock. I will try a shaped piece of steel on it in the morning if in the yard. Thanks.
  #9   IP: 195.93.21.65
Old 07-03-2010, 10:21 PM
Plonk a large lump of clay over it !! FIXED.
  #10   IP: 121.222.161.28
Old 07-03-2010, 10:27 PM
ianoz. ianoz. is offline
Hi Graham ,Mate i thought every JCB backhoe did that. Both of the last ones we have had{and there is bugger all braking involved to heat up oil } you can not put your hand on the diff after travelling,but the front diff ,no problem . It is seperated from the engine and transmission by a tail shaft so it should not get heat transfer from them. I was told by the jcb fiters that the 4 CX had extra weight over the 3 cx and thats why its brakes turned to crap quickly .I was told to use the brakes as little as possible and use the gears to slow the machine down. Which is difficult as there is too big a gap between gears ..Sorry about hijacking your theard rob but it looks like the boys had you well on the way to being sorted .Ian .
