  #11   IP: 95.150.138.38
Old 08-03-2010, 05:57 AM
Default Re: C@t TH560B forklift problem!
ian that is the only one that has done it ,i have had 3 4cx,s and 4 3cx,s
and only one has done it who knows
cheers graham
  #12   IP: 195.93.21.65
Old 08-03-2010, 06:35 AM
Just Crap Backhoes,... then really. The are designed to be roaded and all the manufacturers use road speed as one of the selling points. Only JCB has to have more pitstops along the way .....
  #13   IP: 90.193.135.82
Old 10-03-2010, 09:06 PM
Originally Posted by ianoz. View Post
..Sorry about hijacking your theard rob.
Not a problem at all, but you knew that anyway all good relative info IMHO. Still non the wiser as to why the hell it is doing it though.
I ran it for an hour this morning shifting TVCB's and again it started shoving it out. I have recommended a new breather following stocks mention of them being a sow, and Trax highlighting the fact that are a servicable item. Wont hold my breath on it happening though.
  #14   IP: 95.150.138.38
Old 10-03-2010, 09:13 PM
could you swop the front and rear breathers,and see what happens
cheers graham
  #15   IP: 88.87.189.64
Old 10-03-2010, 09:22 PM
Stock..'s Avatar
Stock.. Stock.. is offline
cheers graham
Now that a very intelligent suggestion,why in the hell didn't I think of that.
"Never underestimate the predictability of stupidity"......
Bullet Tooth Tony
  #16   IP: 90.193.135.82
Old 10-03-2010, 09:38 PM
Suppose thats possible. I know what will happen though.
I'll get cold and dirty,
Tramped back in to the compound last night which gave me the chance to play a little with it today but at 14;00 I went back out on the carriageway again so it might be a while before I get to have a swap around.
  #17   IP: 88.87.189.64
Old 19-03-2010, 09:24 PM
Stock..'s Avatar
Any-more developments????
Bullet Tooth Tony
  #18   IP: 90.193.135.82
Old 19-03-2010, 09:40 PM
Sorry, no! I've been out on the carriageway and not had a chance to get near it again.
I did hear that it was parked and not to be used but suspect that was more to do with an audit that was happening this week and no paperwork, rather than a concern over the oil leak
  #19   IP: 88.87.189.64
Old 20-03-2010, 06:06 AM
Stock..'s Avatar
Lazy git comes lookin for info then doesn't use it,
Bullet Tooth Tony
  #20   IP: 90.196.146.94
Old 02-05-2010, 09:39 PM
UPDATE.!
A new breather was purchased and installed, not by me, so it wasnt me that got an oil bath when the breather was removed not really a bath but there was a lot of pressure apparently
Finally a technical bod, one of them spanner juggler types, was summoned.
He dropped the axle oil as it had way too much in it. Turns out its contaminated with hyd oil, suggesting that the brake seals are shot.
I suppose this is what are called inboard brakes, the brake pipes go to either side of the crown wheel housing not the wheel hubs.
I have to assume nobody here has experience of these beasts. I imagine an axle off and complete strip?
