  #1   IP: 85.195.171.195
Old 21-04-2010, 12:33 PM
Richard's Avatar
Richard Richard is offline
Default Track Roller Guides
On a lot of crawlers I notice they fit these guards. Somewhere I read that they aren't there to keep the track on, but in reality do they help keep it running in line - like for example running forward and back across the side of a hill?
Do these weld to the frame or bolt up? only the parts book doesn't seem to indicate any means of attaching them
  #2   IP: 195.93.21.41
Old 21-04-2010, 08:13 PM
tctractors tctractors is offline
Default Re: Track Roller Guides
Richard, these Guards are Welded onto the Underside of the track Frame, then Wear Shoe's are Bolted to them, they were an extra for a long time when Ordering your New Tractor, plus you could Order the full Roller Guard Package, it was a big Cost in its Day.
tctractors
  #3   IP: 195.93.21.38
Old 21-04-2010, 10:12 PM
The full roller guards are a pain in the arse.
  #4   IP: 95.148.171.254
Old 22-04-2010, 06:12 AM
RolyD8k RolyD8k is offline
just another extra cat can charge for,they cause more problerms
than they solve trapping muck and debre in the rollers but the yanks
love em,when i bought our D6c new in 1973 the drawbar was extra
choice was swinging or fixed.
RB
  #5   IP: 85.195.171.195
Old 22-04-2010, 06:53 AM
Richard's Avatar
OK, so best off to avoid these things....just wondered if they helped keep more worn/slack tracks straight on to the rollers/sprocket/idlers
  #6   IP: 81.153.49.62
Old 22-04-2010, 03:14 PM
Guest1 Guest1 is offline
A mates case 450 has full roller guards and i allways wonder what the rollers are like behindnot good if you like to keep a eye ball check on them.
  #7   IP: 195.93.21.38
Old 22-04-2010, 08:57 PM
Sean precisly, Richard, centre guides are good but with full guides, roller replacement is a much longer job....and allsorts gets caught up in them.
