  #11   IP: 81.174.180.129
Old 17-01-2018, 02:04 PM
Default Re: Mini crusher
Originally Posted by smiffy View Post
The first one is made by ken mills engineering would it be worth speaking to them and see if you can demo something or even find a site using one and transport say an 8 wheeler to them to get an idea
Not sure who else make something similar that isnt huge
Various places hire timeberwalf high speed shredders i dont know if they can be fitted with screens like there bigger brothers to allow a more consistent product
The one may be a haybuster or rotogrind or mobile hammermill various agricultural contractors hirer these out they are meant to cope with pallets so i wouldnt think clays would damage them more than nails
Ken Mills Engineering looks interesting. Once I've separated the wadding from the clays I'll try them.
  #12   IP: 95.150.192.215
Old 17-01-2018, 04:20 PM
Everyone has different experiences with Dealers, some have had success with Liebherr, I simply canít get on with them no matter what I do.
If I had bought ten it may be a different story!
  #13   IP: 82.132.235.144
Old 17-01-2018, 04:54 PM
big jordy big jordy is offline
Not sure if they go down to the size youd be looking to crush to but maybe worth a thought think they are heading to lamma with a demo
http://herbstmachinery.com/herbst-agri-crusher/
Jordan
  #14   IP: 209.93.206.133
Old 17-01-2018, 06:02 PM
Yes, I get what you are saying. Weird though. I didnít think I was being at all unreasonable wanting to prove the product did what it said before buying.
When I bought my first rotary bucket sieve, back when they were first available, Andy Hair from Northern Track put him self out to make sure it was just right and subsequently I bought a further four much bigger more expensive ones from him and have recommended him to numerous people.
  #15   IP: 92.26.218.253
Old 18-01-2018, 05:43 PM
I did wonder if a mobile cone crusher would give the sort of product you are looking for but probably way OTT and too expensive.
  #16   IP: 86.134.213.153
Old 18-01-2018, 08:00 PM
volbar1 volbar1 is offline
I think a jaw crusher would clog up if going down to 10mm?
  #17   IP: 81.174.180.129
Old 21-01-2018, 06:06 PM
Robex seems to have come up with a simple solution. His idea is to use one of my trommel bucket sieves and chuck a few bits of concrete in to smash up the clays.
If I changed the mesh from 5mm to 10, or even 15mm, if the client will go for it and put a couple of large ball bearings in with it (you can get 2kg ones off the shelf) that should separate out the wadding and crush the clays in one operation. Changing the mesh is a bit of a pain as the fine stuff is welded in, but it should work.
Have to talk to the client and see if they are willing to try a test day.
Hopefully if we can come up with the right solution at the right price there may be some ongoing work with it. That would be handy as Carillion work looks like it will take some time to come back on stream.
  #18   IP: 31.49.119.137
Old 21-01-2018, 08:46 PM
I had thought of something rotary with some balls in it .... didn't click on the screener buckets though Gra
here's a source for cheap balls
http://www.fhbrundle.co.uk/groups/05..._Solid_Spheres
  #19   IP: 209.93.206.133
Old 21-01-2018, 08:58 PM
That is dirt cheap compared to hardened ball bearings, although they donít go that large or heavy. 100mm ball bearings are available and weigh about 4kg, but are £80. Trouble is I have no idea what I need. One heavy one seems a good option as I will have to retrieve it after every bucket full, but I donít know.
£1.60 for .88kg is attractive though, but Iím sure 4kg will crush clays, not sure about .88kg.
  #20   IP: 31.49.119.137
Old 21-01-2018, 09:10 PM
look at page 2 Gra
http://www.fhbrundle.co.uk/products/...Diameter_100mm
4.08 kg
Price: £6.80 (Excluding VAT @ 20%)
Prices climb dramatically above 100mm .... so reckon half a dozen of them'd be the kiddies
