  #21   IP: 148.252.129.139
Old 21-01-2018, 09:59 PM
Default Re: Mini crusher
Originally Posted by grahams View Post
That is dirt cheap compared to hardened ball bearings, although they donít go that large or heavy. 100mm ball bearings are available and weigh about 4kg, but are £80. Trouble is I have no idea what I need. One heavy one seems a good option as I will have to retrieve it after every bucket full, but I donít know.
£1.60 for .88kg is attractive though, but Iím sure 4kg will crush clays, not sure about .88kg.
Could you not weld the ball bearing to a chain and into the buck or onto the dipper make retrival easier and if the wadding floats which i would have thought either fibre or plastic would it will be very easy to wash them out i think there are a cople of washer units for sale on ebay for scrap prices from root crop operations
  #22   IP: 148.252.129.139
Old 21-01-2018, 10:10 PM
And could you see about a demo from this company thats dear but the same setup could be created for a lot less i should think if it worked
Look at this on eBay http://www.ebay.co.uk/itm/263062943398
  #23   IP: 31.49.119.137
Old 21-01-2018, 10:59 PM
I'd been considering a ball mill type arrangement Smiffy .... hence the steel ball comments previously ... not thinking of Gra's rotary screening buckets providing the rotating chamber for the balls
  #24   IP: 209.93.206.133
Old 21-01-2018, 11:14 PM
look at page 2 Gra
http://www.fhbrundle.co.uk/products/...Diameter_100mm
4.08 kg
Price: £6.80 (Excluding VAT @ 20%)
Prices climb dramatically above 100mm .... so reckon half a dozen of them'd be the kiddies
Didnít see there was a second page. I recon a couple should do it. Screen bucket is only 1m diameter.
  #25   IP: 31.49.119.137
Old 21-01-2018, 11:23 PM
more the merrier .... and quicker i'd have thought Gra
  #26   IP: 92.24.180.130
Old 25-01-2018, 08:51 PM
robex 210 robex 210 is offline
Talking Re: Mini crusher
Hi Graham
Have you had a trial run yet..
Another option would be concrete pad and a roller ,then screenig bucket
  #27   IP: 209.93.206.133
Old 26-01-2018, 08:37 PM
To be honest Iíve been so busy I havenít had a chance to take it any further.
If and when I get on with it Iíll try and post photos.
  #28   IP: 79.75.92.251
Old 26-01-2018, 09:10 PM
diggerjones's Avatar
Originally Posted by robex 210 View Post
Hi Graham
Wouldn't have thought you would even need a roller, just track over it with a reasonable sized metal traced digger, then like you say ridle bucket
  #29   IP: 92.24.180.130
Old 26-01-2018, 09:47 PM
Glad you're busy,and looking forward to some pics
  #30   IP: 92.24.180.130
Old 26-01-2018, 09:49 PM
Just thought a roll would be cheaper and easier than spraging around wearing up chains and sprockets!!!
