  #11   IP: 185.69.144.72
Old 13-03-2018, 07:13 AM
APH2007's Avatar
APH2007 APH2007 is offline
Default Re: New addition to me Jcb 3c11
Originally Posted by delbouy View Post
Looks like you got the proper old style grading bucket with her too.
Did you get any flat bottom buckets with her?.
Unfortunately not just that old style grader and 2' standard JCB style
Ducking around Wiltshire
  #12   IP: 185.69.144.72
Old 13-03-2018, 07:19 AM
APH2007's Avatar
Next time Iím up with Rory Iíll make a point of looking to see what glass is left on that old scrap machine in the field.
Think Iím going up on Wednesday.
The cabs well past it, but thereís more then likely the glass there with it.
I do have a spare back window frame up the workshop if you need one, it doesnít have any glass in it, but itís a good clean frame.
I still need to go through what glass I have up the yard to see what I have spare for you.
Cheers Derek, rear window frame is good on her, did still have the rubber for window in it, glass wise would be needing sliding side window and finger pull, rear and door sides as u can see, going to be on look out for a dipper as well, as this one has being welded up a lot and looks bent, so its had hard life some when, but engine wise runs sweet as with no smoke or fluid contamination
  #13   IP: 94.195.17.197
Old 13-03-2018, 09:53 PM
topkit topkit is offline
Try First Plant Sales on E bay item number 232530347290 they have a few 3C mk2 items. Also give Rusty Parts and Warburtons a try i am sure they will have a fair few parts available.
  #14   IP: 78.146.178.163
Old 13-03-2018, 11:08 PM
diggerjones's Avatar
diggerjones diggerjones is offline
Think I've got a old 18" jcb bucket some where. You can have
  #15   IP: 82.199.200.158
Old 06-06-2018, 07:24 PM
APH2007's Avatar
Slowly gathering parts for the 3c even buying another one to either use as spares or repair same year as mine possibly from Guilford area by number plate as tidy as mine but cab lot rustier ��
