  #11   IP: 31.52.94.221
Old 20-07-2017, 10:04 PM
Default Re: Weight Block
Originally Posted by EngconUK View Post
I know them as seating washers, but Druid will no doubt have a proper engineering name.
Robert
belleville washers lads, used in packs to form springs, very often.
it's their design use
How's this for a belleville ......
  #12   IP: 31.52.94.221
Old 20-07-2017, 10:24 PM
I'd not bother using the existing holes Huw.
Drill out the two inner ones top and bottom rows and the two outer most ones on the centre row if you really wanted to go for it, then drill and tap the existing weight to suit their alignment.
space the new weight off the existing with suitable spacers .... job done and lot less faff.
  #13   IP: 31.52.94.221
Old 20-07-2017, 10:33 PM
Originally Posted by Cheggars View Post
Any thoughts on how to bolt it on.
The bolt holes are a fraction out.
the holes'll be a fraction out Huw because they're drilled square on to the face of the weight probably .... heading for an imaginary centre point about 30 or more feet in front of the machine, at a guess
  #14   IP: 5.254.163.144
Old 21-07-2017, 08:19 AM
With respect Druid, a lot of weight blocks these days are little better than foundry slag. I'd be happier bolting to the machine proper than to threads in a weight block of unknown strength.
The studding is how I add additional weights to my machine if needed. Makes it really easy to add or remove the second block too.
Besides, I'd say my method was quicker- no tapping. Cheggars has to drill or bore regardless.
  #15   IP: 188.222.214.246
Old 21-07-2017, 08:47 AM
Whats wrong with a good old ratchet strap?
Runs for cover.....
  #16   IP: 95.147.72.5
Old 21-07-2017, 08:49 AM
Cheggars Cheggars is offline
It Haas been considered , Just to try it out
  #17   IP: 31.52.94.221
Old 21-07-2017, 02:56 PM
Runs for cover.....
LOL .... There's two Fs in farmer .... ****ing farmers
  #18   IP: 86.138.18.237
Old 21-07-2017, 03:17 PM
Bit of CT1 would stick it on.
  #19   IP: 31.52.94.221
Old 21-07-2017, 03:39 PM
like I said ..... " There's two Fs in farmer "
  #20   IP: 95.147.72.5
Old 21-07-2017, 05:15 PM
Baler twin would probably do, Just keep wrapping it on.
