Closed Thread
  #1   IP: 86.153.66.214
Old 12-08-2017, 07:05 PM
Pedrod316 Pedrod316 is offline
Default Concrete pan mixer with digger hitch
Jar Met 1200 pan mixer
Hydraulic Drive
Fork slots & hitch for a machine
Good used condition
1750
  #2   IP: 82.20.150.176
Old 17-08-2017, 08:53 PM
strott strott is offline
Default Re: Concrete pan mixer with digger hitch
What size machine was that running on?
  #3   IP: 81.129.233.211
Old 17-08-2017, 08:57 PM
14-16 tonnner , 65mm pins
  #4   IP: 82.20.150.176
Old 21-08-2017, 08:48 PM
Bit big for mine then
  #5   IP: 86.139.112.55
Old 21-08-2017, 09:53 PM
What's the pin centres on that Pedrod, please and where abouts are you?
I presume you pick that up facing you with pins away from you/far side of the mixer ???
what's its capacity and how the hell do you load it if it's on your dipper? drop it off, fill it and pick it up again ???
  #6   IP: 109.155.52.190
Old 22-08-2017, 06:58 AM
S.A.F. S.A.F. is offline
I would think it needs to be loaded with a second machine, I can't imagine it would like to be restarted once a load has been put in.
  #7   IP: 31.48.53.189
Old 22-08-2017, 07:29 AM
Up in the Highlands of Scotland
Will need to measure pin centres,forgot what they were
You need to load it with a digger, takes 3/4 of cube of concrete at a time,fairly heavy when full.
They were picking it up with pins facing machine, to then get the furthest reach to empty concrete, wasn't the easiest to un hitch mind
  #8   IP: 86.139.112.55
Old 22-08-2017, 10:39 AM
aye that was my thoughts too
  #9   IP: 86.139.112.55
Old 22-08-2017, 10:42 AM
I can believe that flat out my hitch is only vertical .... that'd take some getting off
'spose it's convenient for you, where you are .... readymix not round the corner
Closed Thread
