  #1   IP: 86.135.119.179
Old 03-09-2017, 09:38 PM
Default I-Dig systems 1D and 2D machine control.
Hi Everyone,
Thought I'd post about a new system we are doing now I-DIG systems.
Very effective and simple to use system, that can be fitted to a number of machines. It comes in both 1D and 2D variants.
It really is such a simple system. Using 4 wireless sensors, that are fixed using plates held on with 3m super strong double sided tape (it is very strong and takes alot to remove it) so no drilling or welding needed. The sensors are solar powered and never need charged. They are also clearly marked so as to be fitted in the correct brackets.
A Large touch screen in the cab is used for all aspects of the system, from calibration to setting depths etc. When calibrating it will talk you though every step, telling you how to do each step, if something went wrong and how to change it.
You can then, save the machine (as you can swap between machines) so that you don't have to calibrate it every time, and calibrate each bucket and save these too.
A tilt sensor is also available for use with tilt buckets, hitches and tiltrotators, with a fully tiltrotator version coming soon.
In use you can set target depths and slopes etc, as well as distances. No over or under digging. No need for ground workers checking levels, or people in trenches etc. Where ever your bucket point is at is your ref point, so no need for the dipper to be dead straight etc
https://youtu.be/kb67GDYu1cE
The Touch screen and the eyeline display
The 4 sensors, boom, dipper, bucket and 2D cab sensor
Any one looking for more info in these systems, please do get in contact. Id be happy to discuss them i more detail and possibly arrange a demo.
Aiden
  #2   IP: 95.144.40.61
Old 03-09-2017, 10:16 PM
Cartman Cartman is offline
Default Re: I-Dig systems 1D and 2D machine control.
Very interesting, it has potential for drainage work. Only a matter of time until these sort of things come on a new machine I suppose. The one thing missing was the ? which is the decision point for folk.
  #3   IP: 217.44.68.157
Old 04-09-2017, 08:18 AM
Ballpark price would be good.
  #4   IP: 87.115.198.55
Old 04-09-2017, 08:26 AM
I thought it was the I Dig Best system. This looks interesting, but I was really looking for the auto bucket steer to speed up grading large areas https://www.idigbest.com/
  #5   IP: 5.254.163.144
Old 04-09-2017, 09:10 AM
Agree, don't be shy!
  #6   IP: 87.115.198.55
Old 04-09-2017, 05:44 PM
I tried a similar system back in 2012 (AGL EZDig pro), but didn't get on with it. Mainly because the guy selling them sold rotary lazers and didn't know about machines or how to set it up. There were also problems with the wireless link.
Technology has moved on so much since then those sort of problems should have been ironed out.
  #7   IP: 90.254.9.165
Old 04-09-2017, 07:59 PM
Been eyeing up the Trimble system for a while but the price tag is quite lumpy. If the Chinese have managed to make a reliable and simple system as this appears to be then I'm keen.
The youtube videos suggested you could set the size of an excavation with it as well but didnt really explain what would happen if you moved the machine. So for example can I set a size for a soakaway as long as I didn't move but I couldn't tell it I want a trench X meters long but have to move to complete the trench?
To be honest I've got loads of questions on how this works and how I can use it to full advantage. Oh and also the price
Can you do us a youtube video Aiden showing us all the features kinda like Dirt Ninja does with the Trimble system?
  #8   IP: 213.205.252.253
Old 04-09-2017, 08:35 PM
APEarthworks APEarthworks is offline
Hey Aiden
Id be keen on a price on this, i spent a few hours on it in the Netherlands
Cheers Alex
Alex
Turning Mud Pies into Strawberry Tart!
  #9   IP: 88.21.204.134
Old 09-09-2017, 04:02 PM
im sure im too cheap to buy one but would be keen to know some price points for consideration
  #10   IP: 109.157.252.134
Old 09-09-2017, 08:46 PM
It's gone very quiet: perhaps it's a case of- if you need to ask the price, then you probably can't afford it
