  #11   IP: 109.148.182.146
Old 25-03-2014, 08:25 PM
Default Re: Mogmans Projects
Should be fun, got to tow them 1/2 mile and though a set of locks going to borrow a tug from a pal of mine (never piloted one before) so may also have to learn how to swim
sounds like fun mate look forwards to the pictures
  #12   IP: 109.148.237.242
Old 25-03-2014, 08:26 PM
In that case make sure the cameras got a waterproof case!
  #13   IP: 86.165.228.212
Old 26-03-2014, 01:05 AM
just won a job (in the last half hour) cutting up two 100 ton mud hoppers hopefully start early next week
I take it they're 100 ton capacity Paul?
A hundred ton boat on a canal would be a BIG boat!!
  #14   IP: 2.102.14.81
Old 26-03-2014, 07:01 PM
No hundred tonnes of steel in them 28 meters long by 6.5 meters wide and showing 3 meters above water must be over a meters draught, twin hulled mud barges hoping to pull one in on Friday all being well
Oh they are on the river Weaver navigation...............make for sea going vessels
  #15   IP: 86.165.228.212
Old 26-03-2014, 07:10 PM
Can't wait for some piccies Boyo - they're some sort of barge - they bottom open-ers then with a twin hull?
Presumably dragged out to sea to dump dredgings?
Make some serious swimming pools if you could keep water in 'em!
How do you get 'em Mog???????
  #16   IP: 2.102.14.81
Old 26-03-2014, 07:26 PM
No not bottom dump.............one has a thick timber deck to sit a RB 22 on and not the light 22 ton ones..........the ones with two extra weighs on the arse with a drag bucket on
  #17   IP: 86.165.228.212
Old 26-03-2014, 08:19 PM
They fill AND empty 'em with a drag????????? Jeez that must be slow going!!!!!!
  #18   IP: 95.147.116.87
Old 26-03-2014, 09:32 PM
Like this kind of barge?
http://www.geograph.org.uk/photo/3119104
  #19   IP: 2.102.14.81
Old 27-03-2014, 07:17 PM
Originally Posted by GB_Groundworks View Post
Think they are the ones....well they look very similar/identical but they are not moored there that is by Brunner Mond but they may have been moved up stream to Northwich
Will take some pictures tomorrow............going to move one to its final resting place
hope it's a nice day
  #20   IP: 2.102.14.81
Old 28-03-2014, 07:37 PM
Up date today
set of in the tug
to collect these monsters
the problem we had is that because the barges were so tall we couldn't push them
so towing was the only option, you can just see the top of the tug here
was going great guns until we came to the locks...a bit tight to say the least was touching both sides
anyway started at 12 noon and had both barges through the locks sailed 1/2 a mile up the river one moored up safely the other on the slipway ready for cutting all for 4 o clock
