  #21   IP: 109.148.182.146
Old 28-03-2014, 07:46 PM
Default Re: Mogmans Projects
are they of no use commercially mog , seems a shame if they are good
  #22   IP: 2.102.14.81
Old 28-03-2014, 08:26 PM
The top is a bit rotten but they are water tight.....seems a shame but it they kept them what would i do for a week or two
  #23   IP: 204.112.248.160
Old 28-03-2014, 09:36 PM
800CLC's Avatar
800CLC 800CLC is offline
So how do you drag them on land to cut them up? I'm assuming your using your Daewoo/Doosan hydraulic snipper?
  #24   IP: 86.165.228.212
Old 28-03-2014, 10:07 PM
Up date today
set of in the tug
Attachment 21688
to collect these monsters
Attachment 21687
the problem we had is that because the barges were so tall we couldn't push them
Attachment 21689
so towing was the only option, you can just see the top of the tug here
Attachment 21690
was going great guns until we came to the locks...a bit tight to say the least was touching both sides
Attachment 21691
anyway started at 12 noon and had both barges through the locks sailed 1/2 a mile up the river one moored up safely the other on the slipway ready for cutting all for 4 o clock
Jeez that's tight in the locks!! Big old tubs, ain't they Mog.
Must've taken some emptying with a drag, with the bottoms the shape they are, internally.
Good luck with the job.
  #25   IP: 2.102.14.81
Old 29-03-2014, 07:33 PM
Yes Burt took the Doosan this morning..............there is a slipway its a bit tight but they will fit then hook both machines to the front and pull.........only get about 10' at a time though so snip the end of and pull again
  #26   IP: 95.144.115.139
Old 29-03-2014, 08:20 PM
They look like real beauties Paul and such a shame as I doubt anybody will be building more of them in the UK.
However business is business and I'm certain you'll have them dispatched in no time.
  #27   IP: 2.102.14.81
Old 30-03-2014, 10:20 PM
not really a selfy but my brother took this picture of me guiding one of the mud hoppers into the lock
just wished Id had a wash and changed my cloths first
  #28   IP: 2.102.14.81
Old 04-04-2014, 07:22 PM
Bit of an update had a hydraulic oil leak on the machine yesterday it was creating a very fine mist took a bit of finding............. but was a steel pipe that goes to the main lift rams.....on closer inspection it had been 'repaired' before but with it on the machine as it is a pig of a pipe to get off
.......have to take all the pipes of the hoist cylinders first then a couple of clamps and that is the bit you can see the other end is at the rear of the spool valve chest under the steel pipes so after over an hour had it free but then had to get the pipe from between the lift rams
so with the pipe off could do a proper job of welding it cut all the old crap weld off to find the original crack
and layed a couple of runs of proper weld on instead
  #29   IP: 86.166.22.49
Old 04-04-2014, 08:01 PM
Attachment 21732
Attachment 21733
Attachment 21734
Attachment 21735
Yep...... much better!
  #30   IP: 86.165.228.104
Old 04-04-2014, 11:44 PM
Attachment 21732
Attachment 21733
How'd anyone get that much pigeon shit in there?????
Attachment 21734
Attachment 21735
That's a proper lookin' job Mog
Sounds a real PITA job to get at though Boyo
