  #21   IP: 31.49.119.206
Old 17-05-2017, 10:46 PM
Default Re: Bolt on pin cradle
Originally Posted by cps140 View Post
Graham,
I have 100mm 5mm wall of cuts (Hyd tubing) but its far to light in my opinion !!
The closest you will get will be 101.6, but id be going with 12.5 wall at least id even recommend going for the 16.5mm wall. When you see them you'll agree
your best bet would be solid bar, for all the weight your saving..... or if you are really weight critical turn the 101.6 16.5mm wall down to 100m o.d
Just my thoughts, hope it helps
Aiden
what tube are you quoting with 101 x 16.5 Aiden ... can't see it in any of me books ??
It is out there as engineering tubes, but it's finding it ....
I do tend to agree with your min. on a 12mm wall though, other than the fact that Gra isn't really working this hard at all
Thick wall tubes have always been a total PITA to source
  #22   IP: 81.136.79.232
Old 17-05-2017, 11:07 PM
cps140's Avatar
cps140 cps140 is offline
I'm nearly certain i have 16.5mm wall on 101.6 tube..... but now your making me dought myself i know i do on something??
il have a measure in the morning
  #23   IP: 31.49.119.206
Old 18-05-2017, 12:48 AM
LOL .... sorry Boyo ..... 101.6 is usually 6.3mm wall ..... unless it's a special or HDS .... and you'd remember them ...... for the cost
  #24   IP: 31.185.213.2
Old 18-05-2017, 08:38 AM
Graham,
your best bet would be solid bar, for all the weight your saving..... or if you are really weight critical turn the 101.6 16.5mm wall down to 100mm
Aiden
I think you are probably right, about staying with solid bar, although may be interested in the 101.6 16.5mm wall if you have some spare.
As these heads get regularly changed less weight makes them easier to handle. The genuine one at 280kg is so unwieldy that we had to use the machine to line the bolt holes up. My others a about 70kg can easily be manhandled that last mm and if something does go wrong I don't think even steel toe caps will be any good if 280kg fell on them. It also makes the centre of gravity a lot higher which isn't good on the trailer.
  #25   IP: 81.158.74.20
Old 20-06-2017, 11:03 AM
cps140's Avatar
I did check the next day, but havnt been on here much since! It is 101.6 16.5mm wall tube.
Hi Graham, as above, the tube i have is 101.6 16.5 wall, i have some here if you need abit, (a will be ordering about 10m of it for another job real soon)
Let me know if i can help
Aiden
  #26   IP: 185.69.145.7
Old 20-06-2017, 10:09 PM
mogman's Avatar
mogman mogman is offline
Aiden
Think he maybe sorted now
If it an't broke adapt it
If you can't buy it build it
  #27   IP: 86.141.37.109
Old 20-06-2017, 11:50 PM
Dr Pecker Dr Pecker is offline
Overkill at its finest. I just done a bracket for a krupp hm 2500 to fit a cat330 hitch .80/90 pins. HM2500 weighs in at 4.5t.
  #28   IP: 81.154.53.249
Old 21-06-2017, 06:57 PM
Mark10's Avatar
Mark10 Mark10 is offline
100mm pins on a 10 to 17 ton'er that's mental 😂 Our 30 toners aren't even 100mm there only 90mm
  #29   IP: 91.84.160.57
Old 21-06-2017, 08:56 PM
Aiden
Thanks for coming back to me, but Paul (Mogman) has made me a couple of cradles with 100kg saving per bracket.
