  #11   IP: 31.49.119.206
Old 17-05-2017, 01:39 PM
Default Re: Bolt on pin cradle
Originally Posted by grahams View Post
Just having a look on line. Seems nearest is going to be 4 inch od which is 101.6mm. I'll have to have a proper measure and see if it is within tolerance.
Came across cold drawn seemless tube with 4.8mm walls. What do you think?
Too light Gra and'll be 'spensive in comparison to CHS (circular hollow section) double or more ús
the 101 and 88.9'll do, I'd have thought, if Mog can't come up trumps with some drill tube !!
You're not exactly ripping rock with it are you
  #12   IP: 31.49.119.206
Old 17-05-2017, 01:48 PM
just looked at drill pipe spec.s and reckon the wall would be 10mm on the heaviest 4" Gra .....
http://www.oilproduction.net/files/c...ata_Tables.pdf
page 54 .... bottom
another good link mate .....
http://www.nationaltube.co.uk/wp-con...c-Brochure.pdf
  #13   IP: 87.113.25.53
Old 17-05-2017, 06:14 PM
What you need is some 4" drill tube
If I remember will have a look in the yard tomorrow
Thanks,
Look forward to hearing from you.
  #14   IP: 87.113.25.53
Old 17-05-2017, 06:17 PM
The more I look at it I may be causing more hassle than it is worth, trying to get suitable 100mm tube. I had assumed with the wonders of the internet I would just go on line and order exactly what I wanted with no hassle. It seems more difficult than I thought, so may end up with 100mm round bar just for an easier life.
Can still save a fair bit of weight slimming down the rest of the cradle.
  #15   IP: 81.178.213.231
Old 17-05-2017, 07:37 PM
Thanks,
Had a look and the only stuff I have big enough is 120mm OD with a 60mm ID so you could turn it down and still have 20mm wall
  #16   IP: 31.185.213.2
Old 17-05-2017, 07:46 PM
Mog, I'll phone you tomorrow.
  #17   IP: 81.178.213.231
Old 17-05-2017, 09:37 PM
Will be out of the country till Monday
  #18   IP: 31.49.119.206
Old 17-05-2017, 09:44 PM
wouldn't mind greasing yer palm for a few feet/metres of that .. if you could spare it Mog, whenever yer's in Druid country of course ..... make great bosses opened up to 70mm
  #19   IP: 86.113.245.156
Old 17-05-2017, 09:57 PM
A site im on with our 18 tonner has a h e services 13 ton reduced tail machine on it it has the same size pin specs as mentioned I can't even pick them up as I'm 80mm on my 18 tonner 100mm is normally reserved for over 30 ton machines
  #20   IP: 81.136.79.232
Old 17-05-2017, 10:04 PM
Graham,
I have 100mm 5mm wall of cuts (Hyd tubing) but its far to light in my opinion!!
The closest you will get will be 101.6, but id be going with 12.5 wall at least id even recommend going for the 16.5mm wall. When you see them you'll agree
your best bet would be solid bar, for all the weight your saving..... or if you are really weight critical turn the 101.6 16.5mm wall down to 100m o.d
Just my thoughts, hope it helps
Aiden
