  #1   IP: 95.147.72.29
Old 16-07-2017, 10:51 AM
Cheggars Cheggars is offline
Default Weight Block
Morning all,
I'm in need of some extra weight on the back of the Neuson 8003.
Would anyone know of a scrapped one,with the extra weight block on it. or anyone likley to be breaking one.
  #2   IP: 31.50.50.4
Old 17-07-2017, 12:27 AM
Default Re: Weight Block
Originally Posted by Cheggars View Post
Morning all,
could you not get some profiles cut to go under it a bit Huw, or is there not enough clearance?
  #3   IP: 5.80.43.168
Old 17-07-2017, 06:22 PM
wafer weights from a tractor and bolt them , or hang them from a frame
  #4   IP: 95.147.72.60
Old 19-07-2017, 09:35 PM
Thanks, its got 1 weight already bolted on the back, ive found on off a 5 tonner which is a bit smaller( not sure of its weight yet)
The problem is the bolt holes dont quit match the 8 tonner. i'll post a picture when i get a chance.
Would be easier if they were miles out.
  #5   IP: 95.147.72.60
Old 19-07-2017, 09:37 PM
This is plan B, not as tidy but plus is they would be easily removed.
  #6   IP: 5.80.74.246
Old 19-07-2017, 10:24 PM
grifferr grifferr is offline
Be careful when you spin round with the blade up
  #7   IP: 84.93.26.223
Old 20-07-2017, 10:52 AM
Putting a thick slice of plate underneath the back end always looks good to me. There are normally bolts ready to be used and you don't extend the back end any more. A good metal working shop will cut it to shape and drill the holes for not a lot more than the cost of the metal.
  #8   IP: 95.147.72.82
Old 20-07-2017, 03:49 PM
Here's a couple of pictures of the weight block i've got hold of.
Any thoughts on how to bolt it on.
The bolt holes are a fraction out.
  #9   IP: 5.254.163.144
Old 20-07-2017, 05:35 PM
Get some suitable studding- it will need to be 12.9. Screw all the way into the mounting threads. Cut it off with ample to spare. Use a nut to lock the first block in place.
You are now free to fit the second block. Bore the holes out so it fits. You may get away with a larger washer or offset plate depending upon how far out the holes are. For a pukka job, l'd counterbore it to receive the concave washer of a set of convex/concave washers (what are they called again? Paging Druid!) if you can find any large enough. If not then making a conical washer to fit in the bored out hole would also be good.
One thing to watch out for is making sure the second weight is clamped firmly to the first weight, not resting on the mounting studs or bending them Looking at the photo it may need a few slices of conveyor belt between the two at the top, but its hard to say.
  #10   IP: 213.78.124.22
Old 20-07-2017, 06:01 PM
EngconUK's Avatar
EngconUK EngconUK is offline
I know them as seating washers, but Druid will no doubt have a proper engineering name.
Robert
