  #11   IP: 75.158.164.6
Old 28-03-2014, 05:55 PM
candrill.chad candrill.chad is offline
Default Re: Kubota RG60 Parts
I have a couple smatter than me guys who want a go at rewiring the RG60 to by pass the ECU. Anyone know where to find a wiring schematic? Or done this before?
  #12   IP: 92.40.39.124
Old 28-03-2014, 07:06 PM
oldchips oldchips is offline
If you can post some reasonably high res photos of the circuit board, both sides, sufficient to read the part numbers on the chips. Some ECUs use microcontrollers with internal code, inaccessible, some with a separate memory chip that can be read. Never know, might be recoverable.
canycom, kubota, mitsubishi, parts, rg60
