  #101   IP: 213.205.198.125
Old 27-05-2016, 10:28 AM
Default Re: JCB Manuals
There are a good few JCB parts dealers you can find on the Internet. This type of brake is used it a lot of tractors too.
  #102   IP: 86.139.114.16
Old 27-05-2016, 10:45 AM
The mechanism that sits between the brake disks is called an expander. Strip it down and fit new ball bearings and smear a little EP 2 grease on them. Brakes should work fine along with new discs.
It'll look something like these ... the balls live between the discs in a rising ramp groove .... as the actuator rod is pulled and rotates the two discs the balls move up the ramps, push the discs further apart and expands the combined thickness of the two discs, pressing on the brake discs friction material, either side of the expander
  #103   IP: 89.240.236.73
Old 27-05-2016, 11:07 AM
petersjcb petersjcb is offline
cheers , i can take most things to bits, putting them back nowadays is getting harder due to the onset of Alzheimers ( my excuse but think it sometimes) but nice to see what i am looking for without finding the struddlepip in surprise.. cheers lads most helpful...just need a fine day in hebden bridge to carry it out
  #104   IP: 108.172.193.105
Old 29-05-2016, 04:00 PM
JCB8016 JCB8016 is offline
Any one have PDFs of 805 Jcb manuals 805 or 805B
  #105   IP: 86.190.29.181
Old 29-05-2016, 04:11 PM
I might have an 805b manual, will have to check, I could send pics or fax pages to you if I've got one.
  #106   IP: 108.172.193.105
Old 29-05-2016, 04:24 PM
Maybe if you have one I will send you a pm with my email address and you chould email it to me
  #107   IP: 151.227.171.194
Old 10-06-2016, 10:08 AM
davidbrown80 davidbrown80 is offline
hi
could you please send me a JCB 3c parts manual if you would ( rwlong97@aol.com )
  #108   IP: 5.80.92.79
Old 20-12-2016, 05:40 PM
peterpecker peterpecker is offline
Im after a wiring diagram for a 2015 JCB 1CXT if theres one available please
Have a gremlin with the Aux circuit coming on and the dipper is in full extension and i can't retract it!
  #109   IP: 178.167.254.200
Old 26-01-2017, 03:16 PM
##dan## ##dan## is offline
Hi
Has anyone got pdf manuals for the early js series
  #110   IP: 86.179.2.175
Old 01-02-2017, 11:03 PM
steviemax steviemax is offline
is this any help to you? http://www.plantkeyshop.co.uk/epages...ectID=50084195
