  #31   IP: 94.8.49.41
Old 04-01-2015, 06:25 PM
Redash's Avatar
Redash Redash is offline
Default Re: Tips and Tricks
Originally Posted by Davejcb View Post
A new tank ASAP... That's the last thing you want splitting in half!
One my tyre fitted does, if a new tyre isn't sealing onto the rim he puts a ratchet strap all the way around it , which squishes it into the rim..
But it will bite you when you take it off It's the only way though, if a bead buster fails.
  #32   IP: 109.150.200.37
Old 05-01-2015, 10:45 PM
bri963 bri963 is offline
Two spanners together ..... utter bodgery and to be avoided at all costs !!
Your man was obviously well trained thats why he may never have heard of the method. Now he does it all the time he has slid well down the ladder.
Though I have to admit I have used the method ......
And don't let me catch you flogging a ring spanner with a lump hammer, either.....
At least, not one of mine.
  #33   IP: 92.30.15.112
Old 05-01-2015, 10:56 PM
We have a seletion of Slugging wrenches Brian .... proper tools ... for slugging
  #34   IP: 92.30.15.112
Old 05-01-2015, 11:01 PM
We use one of our big copressors .... a 350cfm one ! A flatened out fabrcated fitting fitted to the hose, one quick burst of air with the fitting against the bead and up she goes...Like a cheeta. Last four tyres i fitted wouldn't work with the strap method.
  #35   IP: 81.154.191.95
Old 06-01-2015, 12:38 AM
L M A O
Useful to save the palms more, on a tight mutha, than cracking off with
  #36   IP: 109.150.200.37
Old 06-01-2015, 06:18 PM
Got some myself, but they start at 2 1/2". Not handy for electrical work.
  #37   IP: 94.197.120.249
Old 06-01-2015, 07:27 PM
delbouy delbouy is offline
That's what a bit of scaffold tube is for, slide ofer the top nicely.
  #38   IP: 79.79.204.55
Old 20-01-2015, 08:51 PM
Not really machinery related but handy on sites, use 4" sewer rubbers over your wellies to hold oilskins tight to wellies helps stop stuff going up in between the two,
  #39   IP: 109.150.133.170
Old 20-01-2015, 11:35 PM
Powerfab Powerfab is offline
Could probably start a new thread on 101 uses for sewer rubbers.
1) They make great makeshift bungie cords.
If one don't stretch, loop a number together to get the required length.
2) Also useful as a temporary drive belt when a "V" belt lets go
Is it any wonder there are so many displaced / leaking joints in plastic sewer pipes
Nige
  #40   IP: 79.79.207.128
Old 03-03-2015, 10:56 PM
If your having to fill your machine with fuel cans and machine is like the hitachis and have non return fittings on fuel pump and won't fit into cans a 32 mm water fitting goes straight over the valve connected to a length of pipe straight into can, or a 32 to 25 if using jerry cans
