  #1   IP: 96.43.64.79
Old 13-08-2019, 06:37 PM
Tony H's Avatar
Tony H Tony H is offline
Default Battery Group size JCB MIDI CX
Can't find the Group size on this original JCB battery. JCB # 322/F6640 Here in the states getting a JCB replacement is close to impossible and VERY costly.
Group size will help me find a replacement.
  #2   IP: 96.43.67.24
Old 03-09-2019, 09:42 PM
Tony H's Avatar
Default Re: Battery Group size JCB MIDI CX
Question Answered. Had the time to remove the Battery shutoff from the Frame, Pull the Front grill and Framework off, Take the hardware out of the AC condenser radiator in order to shift it up and out of the way enough to get the battery out. GOOD GOING JCB.
Bottom line is after spending time with a very patient Battery Salesman I find that this battery is a "Group #48". Hope it helps someone.
