  #1   IP: 31.52.88.212
Old 20-12-2017, 07:06 PM
Question so what's this then ??
one for the oldies of the group guys ... or a knowledgeable youngster
  #2   IP: 86.138.19.252
Old 20-12-2017, 07:24 PM
Default Re: so what's this then ??
Armature out of some form of resistance switch? Armature is probably the wrong word.
  #3   IP: 31.52.88.212
Old 20-12-2017, 07:46 PM
right word (for once) .... wrong usage though
  #4   IP: 86.174.118.146
Old 20-12-2017, 09:11 PM
feeler gauge
  #5   IP: 185.16.224.33
Old 20-12-2017, 09:25 PM
scoffcruddle scoffcruddle is offline
Any clues?
I'm obviously not old enough
  #6   IP: 86.113.239.113
Old 20-12-2017, 10:40 PM
A fuse that won't trip using your stick welder lol
  #7   IP: 81.147.100.193
Old 20-12-2017, 10:49 PM
I can't believe you can't see it.....its clearly one of those
Is it related to your latest purchase???
  #8   IP: 88.109.93.23
Old 21-12-2017, 12:06 AM
muckyman muckyman is offline
For measuring the jib angle on a crane in degrees
  #9   IP: 31.52.88.212
Old 21-12-2017, 12:31 AM
Originally Posted by scoffcruddle View Post
Any clues?
Originally Posted by d4c24a View Post
feeler gauge
getting sort of warm ---- ish Gra
  #10   IP: 31.52.88.212
Old 21-12-2017, 12:32 AM
exactly Boyo ............. and nope
