  #21   IP: 86.174.118.146
Old 21-12-2017, 09:24 PM
Default Re: so what's this then ??
hush now Gra WTF you find that ?
its what i said it was someone has chopped the screwdriver bit off
  #22   IP: 87.112.91.122
Old 21-12-2017, 09:28 PM
modelman093's Avatar
Similar but different. think spark ignition.
  #23   IP: 86.138.19.252
Old 21-12-2017, 09:30 PM
He's right you know "This is the LUCAS Screw Driver included in the MGA travel tool kit, used for adjustment of the distributor contact points. "
  #24   IP: 31.52.88.212
Old 21-12-2017, 09:43 PM
yep ..... well done Graham.
this was my Grandfather's so God knows how old it is ...
came across it a few days ago, having forgotten I had it ...
there are no signs of the shaped tip having been chopped off it though ...
looks to be original ..
I'll have a more thorough examination of it tomorrow, but the slot in some of the Lucas points' screws was 'vast' and as it is, it would also fit nicely into the adjusting notches on the base plates, as is. ....
perhaps it's a variation on the theme?
I'll check it out and let you know
Hope no one got splinters, scratching those swedes !!
  #25   IP: 86.174.118.146
Old 21-12-2017, 09:46 PM
well worth keeping
  #26   IP: 31.52.88.212
Old 21-12-2017, 09:47 PM
feeler gauge
I'm sorry Gra .... I completely missed this post of yours .. you were correct to a degree ... and you got it in the end too
  #27   IP: 31.52.88.212
Old 21-12-2017, 09:49 PM
well worth keeping
absolutely Gra .. if only for the fact, it's one of the few things of his I have
