  #1   IP: 86.24.52.151
Old 27-06-2018, 06:07 PM
earlgray's Avatar
earlgray earlgray is offline
Default JCB 8014 head gasket
I just had the head gasket blow on my 8014 at least that is what I suspect as it bubbles the water really fast and pressurises the Radiator blowing out the water and steam. Just wondered how much of a job it is and are there any pitfalls to check out for. If its a straight forward job I will do the water pump, radiator and thermostat while its down.
Thanks
  #2   IP: 87.112.80.100
Old 01-07-2018, 11:17 AM
oldchips oldchips is offline
Default Re: JCB 8014 head gasket
Possibly, just possibly, might be a dead thermostat.
I bought a Ransomes 3250 mower with a cooked head, after much messing around it seems the original cause was a dud thermostat. It opened, but only fully or not at all, caused similar symptoms to your digger. The mower only had 270 hours on it, must have been like it since new.
  #3   IP: 86.24.52.151
Old 27-08-2018, 09:37 AM
earlgray's Avatar
Checked the usual stuff, thermostat pump etc and decided to go for head gasket as they were all working fine. I will still get a water pump and thermostat while it is stripped as it is easier to do them now while it is apart.
I have looked at sourcing the gaskets and TCH do an online shop for the parts obviously not very cheaply though.
I am just unsure how to tell if my machine is tier 2 or tier 3 the serial number is 1283195 but their site still gives me the option of the two different tier machines with this VIN.
Any help on a better supplier and sorting out which type of machine I have would be appreciated as I collect the head from the machine shop tomorrow.
Thanks
