Go Back   The British Construction Equipment Forum > INDUSTRY MATTERS > Situations Vacant / Post your CV
  #1   IP: 86.172.180.211
Old 12-08-2011, 10:19 PM
Default Dozer op
for landfill near to guildford ,must have experience ,5 1/2 day week good rate of pay accommodation if required
email richiefieldatmsn.com (replace at with @ )or 07976 626890
just seen it in local rag ,no nothing about the job , but might be of use to someone
cheers graham
  #2   IP: 62.7.189.216
Old 23-09-2011, 10:55 PM
Guest1 Guest1 is offline
Default Re: Dozer op
cheers graham
Sounds like the ideal job for the devorced man.....if I were in that situation I'd take it.
  #3   IP: 95.144.191.63
Old 25-09-2011, 12:27 PM
Needs experince and a wee bit far away.
