  #1   IP: 168.1.79.113
Old 23-08-2017, 09:32 AM
Grumpyone's Avatar
Grumpyone Grumpyone is offline
Default Hymac 580BT Dimensions
Hello Gents. Looking for dimensions for the Hymac 580BT digger as a cobber of mine builds models of earthmoving gear and trucks/lorries to scale then enters them in shows. Everything from the lengh width and boom reach if anyone has any details or knows where else I can search info from. Thanking you all in anticipation. Grumpyone/Graham from here in Aus.
  #2   IP: 92.24.180.172
Old 27-08-2017, 12:42 PM
robex 210 robex 210 is offline
Default Re: Hymac 580BT Dimensions
Hi Graham
Hymac constsution machinery have got a facebook account,so I'm sure somebody on there would be able to help
Good luck and hope this helps
Roger
  #3   IP: 31.52.94.169
Old 27-08-2017, 11:30 PM
Also lots of enthusiasts on the C. M. N. could probably give you leads if not dimensions
  #4   IP: 104.222.131.8
Old 29-08-2017, 01:46 AM
Grumpyone's Avatar
Thanks for your reply Roger I'm not on FB anymore but I will let him know and he can look for himself.
  #5   IP: 104.222.131.8
Old 29-08-2017, 01:47 AM
Grumpyone's Avatar
Thanks Graham will have a look.
  #6   IP: 81.174.242.105
Old 28-10-2017, 10:58 AM
oldchips oldchips is offline
I have only details for the 590, no idea how different it is.
Looking through the operating manual for the 590 and see that the whole hydraulic diagram fits on one A5 page, those were the days, my JS150 needs A3 and magnifying glass!
  #7   IP: 168.1.93.47
Old 11-11-2017, 09:42 PM
Grumpyone's Avatar
Thanks and sorry for the late reply. The search continues but he may have to wing it a bit.
  #8   IP: 85.210.151.128
Old 16-11-2017, 01:11 AM
muckyman muckyman is offline
Trouble finding the brochure but its just a 580 with heavy duty under carriage so track length 11ft 4
counterweight to front of arm folded in 24ft 6
machine height 9ft 3
width8 ft to11 ft 8 dependant of pads
dig depth 13 ft 6
reach 28 ft 4
dump height 19ft 6
hymac 580bt dimensions
