  #1   IP: 87.74.155.183
Old 08-06-2020, 08:21 AM
oldpilot oldpilot is offline
Default Thwaites alldrive six tonne dumper
Can anyone help with this?
I need the workshop manual for the twaites Alldrive 6 tonne dumper model: MACH 065\3
The clutch is dragging so it’s difficult to select the gears.
It’s operated by an electronic switch on the pedal!
It has the shuttle box with the forward/reverse on the dashboard switch, clutch pedal switch and a 4 speed manual gearbox which is grating and difficult to select as the clutch is dragging!.
Any suggestions?
  #2   IP: 212.88.42.35
Old 09-06-2020, 12:17 AM
Default Re: Thwaites alldrive six tonne dumper
The clutch is dragging so itís difficult to select the gears.
Itís operated by an electronic switch on the pedal!
Any suggestions?
there is no clutch on that ... the pedal is merely a disengage switch for the torque converter ... does it drag when the fwd/rev switch is in neutral ??
I might have a manual for the 6t alldrive on PDF somewhere ... will have to have a look
  #3   IP: 87.74.155.183
Old 09-06-2020, 08:12 AM
So will changing the transmission oil do the trick V8?
I doubt it has been changed in over a decade.
  #4   IP: 212.88.42.35
Old 09-06-2020, 10:33 AM
can't hurt for sure ... be careful what you put in .. IIRC it's ATF-Dexron free -- I think??
gear box will be different - probably
if the search was working on here I am pretty sure this has been discussed before, but finding it is not easy without the search.
was working fine, but gone again recently ..
try joining here .. https://www.planttalk.co.uk/ .... and posing the Qs
  #5   IP: 87.74.155.183
Old 09-06-2020, 02:48 PM
It's a blooming nightmare, there are 168 different ATF oils and without a
manual there's no way to identify which one is required!
There's no search that returns a result for the MACH 065\3 model number
that's stamped on the plate!!!
And 6 tonne alldrive 1997 has a complete range and the nearest think I
could find was" Liquimatic Super ATF Transmission Oil"
  #6   IP: 212.88.42.35
Old 09-06-2020, 10:38 PM
think you're gonna have to talk to Thwaites Boyo ... mine is '97 swivel, 6t Alldrive, shuttle, 4 speed ...
just looked and the manual I have is for a manual (clutch) lister/petter engined 6t all drive
mine has a 4 pot perky in it .... JCB axles/box/shuttle, etc. and touch a LARGE piece of wood has never given any issues in ten years ...
sorry I can't be more help .... try plant-talk
