  #371   IP: 5.38.13.34
Old 13-01-2018, 01:32 PM
conorcx130's Avatar
conorcx130 conorcx130 is offline
Default Re: Various Pictures
PD 1st pic is actually part of the filling process, we dump the water then use a grader to essentially turn a furrow and add more water and turn it back to mix it properly, then grade off level and compact.
Mart, the subbase on this job is coming from Oman, however there are a lot of quarries in the northern emirates which is probably a 5 hour round trip in a truck. We bring it in 45 m3 trailers and stockpile it at site then shift it around with 6 wheels as and where we need it. Plenty of water normally does it for the formation, depends on the type of sand as well.
Cheers scroff, horses for courses I suppose, it wasn't somewhere I thought I'd end up. Apart from the high cost of living it's a great place, well worth seeing once at least.
  #372   IP: 86.153.0.166
Old 13-01-2018, 05:34 PM
Ah, thatís interesting: I guess too dry and itíll be impossible to compact.
  #373   IP: 31.49.119.137
Old 13-01-2018, 08:22 PM
as per usual Boyo ..... everything is on such a wow factor 10 scale
Some amazing stuff, I doubt I'd see, without your efforts in putting it up here for us ... Thank you
